AoS Start Collecting Army
Discussion in 'Seraphon Discussion' started by paulie99, Mar 25, 2019.
  1. paulie99
    paulie99 Member
    Greetings all!
    If this is posted in the wrong spot, my apologies (just joined this great forum today).
    My sons and I are brand new to AoS (coming from 40k). We're starting small (my sons are Stormcast and Nighthaunt), and I decided on the Seraphon. From 2 start collecting boxes, I have built/converted to the following:
    -Oldblood on Carny
    -10 knights
    -20 warriors
    - Astrolith Bearer
    -starpriest
    -Olblood on foot
    -scarvet on cold one
    So, just looking for suggestions on what to make of the last 5 knights and carny/trog. I'm thinking 5 knights and a troglodon, but any suggestions are much appreciated. Cheers!!!
  2. LizardWizard
    Welcome to Lustria
    Just build the Knights as they are. Lances are the normal go to weapon but blades are pretty similar. once you have 15 Knights you can build the Firelance Starhost. For the last Carno kit I would make a Scar-Veteran on Carnosaur. it's a decently killy model and its command ability synergizes well with the Saurus Warriors or Knights.
  3. paulie99
    paulie99 Member
    Thank you for the fast response!
    I hadn't thought about the battalion (being very new to AoS lol).The Scar-Vet synergy makes sense as well.
    Thanks very much again, Cheers!
  4. Killer Angel
    Get also a Slaan as soon as you can. ;)
    And welcome aboard!
  5. paulie99
    paulie99 Member
    Slann starmaster is being ordered this week, thanks for the response, Cheers! :)
    LizardWizard and Killer Angel like this.
  6. Killer Angel
    On a side note, if you are allowed to proxy some models (basically, your Oldblood on Carno as a ScarVet on Carno), then it could be better to build the second dinosaur as Troglodon...
  7. LizardWizard
    Along a similar line, if you are not planning to run both an Oldblood and ScV on Carno at the same time you can use both kits to build the Oldblood and the ScV. With a small hand drill and some magnets you could make the two riders interchangeable. Which would allow the riders to be swapped as needed and free up your second kit to be built as a trog.
    Killer Angel likes this.
  8. paulie99
    paulie99 Member
    Great suggestions all! Appreciate the help, cheers!!!
  9. Wilhelm Stürmer
    Exactly what I did. My Carnosaur has interchangeable riders and the second box was made into a Troglodon.
    Killer Angel and LizardWizard like this.
  10. paulie99
    paulie99 Member
    Only issue I have is I glued the oldblood on the carny. I have had success separating glued parts on different models so I'm going to see if it can be done without too much fuss. If not, I may just do the scar-vet and have both. Cheers to all for the great advice! :)
  11. ILKAIN
    ILKAIN Well-Known Member
    someone needs to @Crowsfoot and his amazing conversion post :)
  12. Crowsfoot
    What did I miss?
  13. ILKAIN
    OP is looking for advice on his get started building, I know you have a great tutorial.
  14. Crowsfoot
  15. paulie99
    paulie99 Member
    Big thanks to Crowsfoot, that's where I actually started when I got my first start collecting box (amazing tutorial!).
    I've actually settled on the final builds: I'm doing the last 5 knights as standard. I was able to remove the glued on Oldblood from the carnosaur, so I am in the process of magentizing so I can go between the oldblood and scar-vet on the carny. Lastly, I decided to build the troglodon (I love the model!).
    Cheers and thanks to everyone for their excellent help and advice. Now it's time to paint and then build my first 100 point list for an event at our GW store on April 20 (I will be posting in the army list thread when I have my list).
  16. Crowsfoot
    Don't forget a paint blog so we can really get you motoring.
  17. paulie99
    paulie99 Member
    Well I am a low to average skill painter (working to get better, 2 thin coats and all that lol), but I will definitely post some pics as I go.
    Cheers!
  18. ILKAIN
    I am the same. Check out my Blog/insta full of my painting (it's in my signature)... I have been doing it for less than 2 years and have ZERO natural talent for art. honestly, my buddy who (until very recently) owned an LGS sat with me a few times and just went over a few easy to learn tips and tricks.
    best tip I ever learned was when to stop. hold the model out at full arms length. if it looks good at that distance it is good.
    Go easy on the primer spray and use one size smaller brush than you think you should when painting. It will take you a little longer, but if you are like me it will give you a bit more control. Don't skimp on the shade, it works magic for contours and contrast.
  19. paulie99
    paulie99 Member
    Great advice, thanks very much! When to stop is probably one of the best piece of advice. I will post some WIP tonight/tomorrow.
    Cheers!
