Starting Lizarmen and yes I heard the rumors
Graymage
New Member
Messages
Likes Received
Trophy Points
Hello, I recently started Lizardmen, mostly due to the fact while I have Tau and Tyranids for 40k I did not have a fantasy army to play with my friends at the hobby store.
So I ended deciding to go Lizardmen, it was either them or Dwarves and I wanted a bit more options for a color scheme.
This is all the units I have on order. spread out a bit to make it easier on the finances.
Lizardmen Battalion x2
Ripperdactyl Riders
Bastiladon with Ark of Sotek
Stegadon x2
Tetto'eko
Lord Kroak
Slann Mage Priest
Salamander Hunting Pack x2
Gor-Rok
Chameleon Skinks
Oxyotl
Chakax
Saurus Oldblood on Cold One
And Yes I know this is overkill for starting a faction but I prefer to do a faction or army with a very solid unit selection.
My Meta has already decided to see what happens for 9th for if we need to convert or just stick to 8th Edition.
I would likes some thoughts on unit equipment for when I start equiping and what versions to make.
That and while I am familiar with 40k some of the terms and mechanics for fantasy are confusing me especially 2 things, Battle Standard Bearer and Lores.
Welcome to the forums!
I don't fault you for buying an army now. While GW will probably do something we don't like for 9th edition, dropping Lizardmen does not seem to be one of those actions.
If you buy some empty 40 mm bases you should be able to use the snake basing bits that come with the Cold One Riders in your Battlalion boxes to make several Swarms. So that's a unit that will cost you next to nothing.
You got a good set of minis. I would suggest buying a box of Skinks. All those models and only 24 Skinks. I'd buy a Skink Priest or two.
There are certainly models you could get, but you seem pretty set for a variety of armies without buying more stuff. You haven't bought any stinkers though most LM players prefer the Solar Engine over the Ark of Sotek and Chakax models are usually fielded as Scar Veterans or TG unit champions.
Now you know why I posted this thread. To find out what I need or what to make. It wouldn't take much to add Skinks and my store already has Skink priest on hand.
Sounds good, I recommend building most of your Skinks as Javelin Skinks instead of Blowpipe Skinks. They have better saves and they can still hit with poison at long range while moving. And they work for Cohort or Skink Skirmishers.
To narrow down future purchases, you should consider looking at this thread or cherry pick the Tactica Index to look at topics that interest you.
oh and the Bastildon is the full kit. as I have yet to get any of the models.
Well then you probably want to go with the Solardon, I've read people saying "The Ark did okay" but no one has yet to say "I like it better than the Solar Engine"
You probably don't need Chakax (though the model LOOKS badass). You can also use regular Skink for Chameleon Skinks with the right paint job but if you like differentiated models go for it. I like Chameleon Skinks better than Terradon Riders though some disagree with me and others prefer both.
Back
Top
