8th Ed. Stegadon and howdah crew help
Discussion in 'Lizardmen Tactics' started by Carnosaur Nr1, Sep 16, 2013.
  1. Carnosaur Nr1
    Carnosaur Nr1 Member
    How does the giant blowpipes work?
    Do I get -1 to hit for multiple shot and -1 to hit for long range if the enemy unit is over 9 inches away and do I get -1 to hit if the stegadon moves or marches?
    Can i buff the giant blowpipes with lore of the beast signature spell that gives 1 to strenght and 1 to thougness?
    It would be nice if you could give page suggestions on where I have to read
    :beaver:
  2. arcabis
    arcabis Member
    well yes you take this penaltys also you can't shoot after you march, also yes you can buff the steg with the signature also you get -1 to cast because is monster if iam correct also i think the skinks crew take +1 str +1 tougness.
  3. Anton_S
    Anton_S Member
    Yes to all penalties. They apply as there is no exception removing them. Basically this means you can only shoot them at less than 9" or when standing still as they are useless if you can't get poison (which you can't at 7+ to hit).
    No to boosting the strength. Changing the S of the skinks will help them in combat, but the S of the blowpipes is fixed at 3 whatever the S of the skinks shooting.
  4. n810
    4D6 Shots is not the same as multishot, so i don't believe you pick up that penality. ;)
  5. Carnosaur Nr1
    I have heard now 2 ppl that say you can buff and 2 ppl that say you cannot buff the blowpipes any page suggestions I should read to know what is right?
    I was also thinking it shouldnt get a penalty for the 4D6 shot but I cant tell how it is.
  6. arcabis
    arcabis Member
    it say's multy shots (2d6) ... i hope you are right :D
  7. Rhodium
    Rhodium New Member
    No wildform does not increase the strength of the giant blowpipe.
    Under the weapon profile it says strength 3, this is independent
    Of the skinks strength therefore making the skinks strength
    4 has no effect on the blowpipe
    Conversely, javelins state strength "as user" therefore if
    You increase the strength of a skink with a javelin
    Then the jav shot becomes strength 4 too
    The difference is due to th strength column on the weapon Profile
  8. Carnosaur Nr1
    So you cant give the chameleons skink the buff either because blowpipe is strenght 3 not as user?
  9. A Steaming Kroak
    A Steaming Kroak Member
    Page 45 says Multiple Shots (2d6) - so you get -1 for this
    You get another -1 for moving (can't march)
    You get another -1 for long range (over 9")
    Basically, if you move and shot at long range then the crew should just use their javelins or you will hit on 7's with the Giant blowpipe.
    Wildform does not affect the blowpipes (still str 3), but it will affect the Javelins because they are at the users strength.
  10. A Steaming Kroak
    This is correct. The buff will only affect their hand to hand str.
  11. Carnosaur Nr1
    New question can I shot with the giant blowpipes if someone charges me?
  12. n810
    Yes they can stand and shoot. :smug:
  13. Anton_S
    Anton_S Member
    That was the case in the old book, but sadly not in the new one. It's a hidden nerf.
    Stand and shoot can be good, but again, you need the enemy to be within 9" to get poison.
  14. Carnosaur Nr1
    Can you shoot with the blowpipes when you are in combat?
  15. Wizgamer
    Wizgamer New Member
    Cannot shoot whilst in combat....
    Quick point to make regarding the 'marching and shooting' scenario.....
    LM book says cannot fire the giant bow if marched. Does not mention this for the blowpipes........ oooooo
    What is everyone's take on this??
  16. A Steaming Kroak
    Normally under the rules of shooting you cannot march and fire. Skirmished units can, but this is an exception. I don't think that there is an exception for monsters. The blowpipes follow normal rules for shooting, so they shouldn't be able to march and fire.
  17. Wizgamer
    Wizgamer New Member
    I agree but it strikes me as odd that they specify it for the bow but not the pipes.....
  18. Carnosaur Nr1
    Read this when I searched lizardmen tactics
    Stegadon: Fuck Me. Its a bolt-thrower mounted on a DINOSAUR! This unit is fucking fun, but also effective, put simply its a two-in-one package, you get a bolt-thrower that can move and shoot, even when in combat, and a big monster that can crush things under its... paws? Crewed by Skinks because you need a BS above 0 to fire anything, its AWESOME. It can shoot while in close combat, meaning you can either fuck up whatever is about to get crushed, or you can fire at other units as a way to say "COME GET SOME BITCHES!". Its pretty good, but its defenses are a little weak for such a massive fire magnet. A good choice and a fun one, every time.
    Rare Units
    Ancient Stegadon: You thought the above was awesome, this guy is tougher, hits harder in combat and does 4d6 blowpipe shots, again it can do this in combat. Again you will see infantry die with this angry old bastard. Then there is the special version mounted by Skink Priests...
    This is the thread
    http://1d4chan.org/wiki/Warhammer/Tactics/Lizardmen
  19. Enkill3
    Enkill3 New Member
    You can't use the ranged weapons in combat,....
  20. A Steaming Kroak
    I think they do this because a bolt thrower cannot normally move and fire.
