7th Ed. stubborn cold blooded
Discussion in 'Rules Help' started by lupercal, Apr 27, 2009.
  1. lupercal
    lupercal New Member
    just thinking that in the rule book it says that stubborn is on unmodified leadership test so does that mean no cold blood roles or am i missing something cause combined that would be really great for us but it feels kinda cheap so i was guessing that it was
  2. Sammy the Squib
    Sammy the Squib Member
    unmodified just means you can't use the general's ld or any other modifiers. but you still get cold blooded.
  3. strewart
    Yeah cold blooded works with stubborn, stubborn just means + or - modifiers, not only generals leadership but the leadership of a non-stubborn character in the unit (you choose whether you want his higher modified leadership or the lower stubborn) and negative modifiers from combat res. Cold blooded is fine.
  4. lupercal
    lupercal New Member
    so if you take the horn and put characters on coldones in all your units you have a stubborn army with coldblooded this might be why the horn costs so much
  5. Craken
    Craken Well-Known Member
    True and don't forget Terradons are cavalery also
  6. strewart
    Oh wow I didn't consider terradons as being cavalry, that is a cool little boost.
    Unfortunately, terradons and cold ones are in the same special slot so you are limited to 4 stubborn units for your 100 points.
  7. lupercal
    lupercal New Member
    yes but as i said if you put a hero on a cold one in a unit of saurus warriors then they become stubborn like the hero so your units of stubborn just increased dramatically
  8. Xerek
    Xerek New Member
    I thought heroes didn't transfer their stats to the unit?
    EDIT: nevermind. a hero (effectively) transfers his stubborn to the unit, big book pg 78-79
