If a unit fails their roll for Stupidity, they stumble forward in a straight line. What happens if they encounter an enemy unit during their "Stupid" move? In 7th, I believe it counted as a charge, but I don't see anything that specifically addresses this in 8th. Am I missing something?
It is treated as a failed charge (pg 76 brb). I does not mention anything in regards to hitting another unit. Unless it was Faq'd, I would say that you would take a dangerous terrain test for the models passing through the unit you hit and emerge on the other side of the unit.
That doesn't make any sense. They would stop 1 inch away from the opponent as a failed charge. The movement from a stupidity test is counted as a failed charge, you never move through another unit from a failed charge because you never reach them.
You are right, I forgot about that. I made that assumption without remembering the 1 inch rule about stopping.
