Quick question on the Slann power that has him cause terror. Is the only benefit of this the radius check at the start of another turn? I ask this because you only take fear and terror tests when you will be coming into contact with a fear/terror causer on the charge, and since you are not contacting the Slann, the should be no test. Also the fact it's a US4 which won't cause very much to auto-flee when a combat is won. Thanks in advance!
If you put him into a TG unit then yes, that would be all he would do. If you run a lone wolf though it's more useful And I think he's actually only US3
it also makes any unit he joins immune to fear and terror... not the best discipline unless you want to go with a lot of terror cause in your list
If the Slann joins the TG then the TG automatically become Immune to Psychology, so there's no point in paying the points to make them immune to terror as well
oops forgot about that.... Well I Guess it only applies if you have him in a saurus unit instead of a temple guard unit then. ... not the best idea, I know...
