thickness
Discussion in 'Painting and Converting' started by Ssword1995, Jan 22, 2013.
  1. Ssword1995
    Ssword1995 Member
    Anyone have a way to make the gold paint thicker? Any help would be very much appreciated!! :D
  2. Eladimir
    Eladimir New Member
    If your referring to the fact that it doesn't cover very well on the first coat no it doesn't
    Rather than thicken your better off applying a couple thinner coats. If its thicker or you try and glob it on to get coverage you'll lose the details and the end result won't look great.
  3. Qupakoco
    Yes, many thin coats is the way to go. You should also paint the gold parts brown first. The brown base-layer does wonders for making the gold stuff look thicker.
  4. Ssword1995
    Ssword1995 Member
    Thank you guys so much. And do u think mournfang brown coat then burnished gold would work?
  5. PossumCraft
    PossumCraft New Member
    This used to drive me insane till I picked up Gehenna's Gold (Citadel Layer) which covers most everything in 2 coats (sometimes 1). It's far better than the older golds which took 10-15 coats lol
  6. Ssword1995
    Ssword1995 Member
    Man i tried using the brown coat then the gold and it makes my cold one champ look amazing
  7. Qupakoco
    Seems like it worked for you! But yeah, any brown will be ok. I guess that middle brown would give the best results. A tan or a near black-brown color would probably still give the same splotchy coverage issues.
    I'll have to look into this stuff.
  8. Ssword1995
    Ssword1995 Member
    It works really well since it sticks to the paint and not the plastic since its like a wash
  9. Scalenex
    I've had some luck if I let the paint dry on the brush a bit before starting painting. That reduces gold down to two or three coats instead of four or five.
  10. Sandrockkai
    Sandrockkai Member
    I'll echo the Gehenna's Gold over a brown base coat. I'm working on uploading my pictures, but I've had a great experience with this technique.
  11. Ssword1995
    Ssword1995 Member
    If you could post like one pic on here so i can see it or tellme when u do id be most appreciative :)
  12. Sandrockkai
    Sandrockkai Member
    I just added my paint log. Everything that you see there that's gold got the following treatment:
    Black primer.
    Deathclaw Brown basecoat
    Gehenna's Gold layer
    Seraphim Sepia wash/shade
    I'll probably grab the Citadel Dry: Golden Griffon in order highlight some areas the next time I'm in the shop, but I'm pretty please with the current result.
