8th Ed. Thoughts of 1000p from Sweden
Discussion in 'Lizardmen Army Lists' started by johho, Mar 12, 2014.
  1. johho
    johho New Member
    This is my second setup, my first one got creamed by Ogres. So I am gonna try this one.
    Lizardmen 1000p
    HERO:
    Saurus Scar-Veteran
    - Enchanted shield
    - Luck Stone
    - Sword of Striking
    - Cold One
    - Level 2 wizard
    - Cube of Darkness
    - Dragon Helm
    CORE:
    Skink Cohort*24
    - Musician
    - Standard
    - Kroxigor
    - Kroxigor
    - Kroxigor
    Saurus Warriors*15
    - Standard
    - Musician
    SPECIAL:
    Cold One Riders*8
    - Standard
    - Musician
    What do you think of this set up? I will mostly face Ogres and Chaos Warriors.
  2. Mux
    Mux New Member
    As a fellow Swede I'll have to give my 2 Öre. (Cents for you other fellas)
    First isn't Dragon Helm a magic armour? In that case your priest can't take it. Sadly. If you want the 2+ ward vs flaming I suggest Dragonbane gem in the enchanted items section.
    A cohort will die quickly and the Kroxigors seems to just be a waste of points. Rather have a bastiladon for the same points.
    Cold ones are nice thought I can see them fall easy from both from Ogre shooting and WoC CC.
    Personally I would take a totally different list to fit my playstyle. Nevertheless. Good luck! Krossa dem för fan!
  3. n810
    I find my cold ones are generaly the only thing that holds up against Ogres.
  4. johho
    johho New Member
    I changed it up to this setup instead. And I know that Krox with skinks isnt optimal, but I just like the unit :) And I know that the skinks will die in horrible numbers, this is not my way to play any game. Normaly I dont like to anything that is some sort of sacrificial unit. But I just the big Krox with those small skinks.
    As the points will get higher I will also put in TettoÉko in that krox-unit. Or atleast I will have that possibilaty.
    HERO:
    Saurus Scar-Veteran
    - Light Armor
    - Dragonhelm
    - Dawnstone
    - Halberd of Striking
    - Cold One
    - Level 2 wizard
    - Cube of Darkness
    CORE:
    Skink Cohort*24
    - Musician
    - Standard
    - Kroxigor
    - Kroxigor
    - Kroxigor
    Saurus Warriors*13
    - Standard
    - Musician
    SPECIAL:
    Cold One Riders*8
    - Standard
    - Musician
  5. Zwuppie
    Zwuppie Member
    Well here's a list that worked for me against ogres, the Lord choice is an very important part of this list because he don't die in these battles, only if you have loaded dice and only roll 1 all the time!
    Saurus Oldblood
    - Sword of might
    - Armour of destiny
    - Dawnstone
    - Shield
    Oldblood has 1+ rerollable and 4++, Strength 6
    Lv. 2 Skink Priest w/ Lore of Heavens
    - Ruby ring
    Always swap one of your spells for the signature spell! Very good spell in games with these sizes. Try having two augment/hex spells! Because you have ruby ring
    29 Saurus Warriors
    - Musician
    - Banner
    11 Skink Cohorts
    3 Ripperdactyl Riders
    Flank the ripperdactyls, try to get behind the enemy after vanguard, the priest is to support your units which are in combat. If you play against Mournfang Cavalry then you have to put your oldblood (with 29 saurus) to that unit! The rippers could take care of the rest of the units because you have two blot toad markers which let you mark almost the half of his army!
  6. johho
    johho New Member
    Okej, after a trip to the store I have changed this up a bit. And I will be facing Ogre, Warriors of Chaos and Dark Elfs (with only fast cavalry and a warhydra)
    I threw out the Skinks/krox and I put in Rippers and a Bastiladon.
    Tactics is to Toad the mournfangs and then land 1" behind them. This forces them to either turn around or to run away. In either case they will not be able to charge me and I will be able to charge them instead. The mournfangs was a problem I really needed to solv and I belive that this is the answer for that problem.
    I haven´t battled with the two others yet so I dont know what the problems will be with them. The Dark Elfs will however be a problem since I cant catch them. And my magic wont be enough I think.
    HERO:
    Saurus Scar-Veteran
    - Light Armor
    - Dragonhelm
    - Dawnstone
    - Sword of Striking
    - Cold One
    - Level 2 wizard
    - Cube of Darkness
    CORE:
    Saurus Warriors*12
    - Standard
    Saurus Warriors*12
    - Standard
    SPECIAL:
    Ripperdactyl Riders*3
    - Solar Engine
    Cold One Riders*5
    - Standard
  7. VampTeddy
    VampTeddy Active Member
    The haæberd of striking is not an existing item - you do not get to make regular weapons magical.
    You could not for example have a giant blade great weapon for +5 strength.
    You get a hand weapon which is magical - the text intends for it to be that his sword, or his axe, or his club is of striking his regular handweapon is thus suddenly titled "handweapon of ***".
  8. johho
    johho New Member
    Okej, I must have misread it then. Changing it back to sword then :)
  9. Zwuppie
    Zwuppie Member
    Hmm you can better combine the two saurus units, 24 saurus (6x4)! If the necessary you can add the scar-veteran to this unit to clam your 4+ lookoutsir (not same unittype)
  10. johho
    johho New Member
    A bit of a rule question. Since I know that this will be a discussion in my group.
    The Rippers has Frenzy. Must charge if able to.
    They also has Vanguard. May not charge the first round if I win the diceroll to start the game.
    Wich rule trumph the other rule?
  11. johho
    johho New Member
    Next weeend I will expand this set up to 1200p. Just adding more Warriors and more cold blods.
    I will meet with my friends Ogres that has a list as follow:
    Firebelly (with ironguts)
    6 Ogres
    5 Ironguts
    4 Mournfangs
    4 Ledbelchers
    So it will be intresting to see how it goes.
  12. johho
    johho New Member
    And another rulequestion:
    Rippers needs to be 3+ to form a unit.
    Is it possible to take 2 rippers and add skinkshief on ripper to add the 3+? Of do a unit with that set up need 3+ skinkshief/ripper?
  13. VampTeddy
    you need 3 regular rippers, and you cannot per the normal rules join a chief on a ripper to that unit, unlss your friend allows it. The BRB states that you cannot join units of fliers, no exceptions are noted in our army book.
    Hope this helps :)
  14. Zwuppie
    Zwuppie Member
    Which will be FAQ'd, if GW gonna bring the FAQ soon...:)
  15. johho
    johho New Member
    Thanks for bringing clarity on that.
    What about this question?
  16. Zwuppie
    Zwuppie Member
    If you vanguard and you go first the rippers aren't allowed to charge even if they have frenzy!
    If you vanguard and you go second the rippers are allowed to charge so they must charge because of their frenzy!
    The first scenario is good for you, because you can bring them into a great position! If the second scenario you can have some problem with redirecting blocks, Ogre sabretusk for example... With a leadership of 5 you won't be able to pass your leadership check often!
  17. johho
    johho New Member
    I shall see if it is possible to keep them near my general for the first round so they can se his leadership.
  18. johho
    johho New Member
    Tomorrow I will try my 1000p army against WoC and Empire. And I have a 1200p setup that shall be game against Ogres.
    Really looking forward to this and hoping for the best :)
  19. Zwuppie
    Zwuppie Member
    What is de definately list you will run against them?
  20. johho
    johho New Member
    1000p
    HERO:
    Saurus Scar-Veteran
    - Light Armor
    - Dragonhelm
    - Dawnstone
    - Sword of Striking
    - Cold One
    - Level 2 wizard
    - Cube of Darkness
    CORE:
    Saurus Warriors*12
    - Standard
    Saurus Warriors*12
    - Standard
    SPECIAL:
    - Solar Engine
    Cold One Riders*5
    - Standard
