I have an question. this is what happend: After combat result my unit won the combat and he lost his LD test, so he ran. I pursue my dice roll is higher then his, so i would caugth his unit and it would be destroyed. this is pretty much standard But: behind his unit that broke there was an other unit of his army and his unit fled trough this one, causing panic but he made his LD so they didn`t panic or run away. what happens to his fleeing unit? is it destroyd? because i rolled higher with my dice. Or did it escape? because my unit hits his other unit that didn`t panic
If I remember correctly, the feeling unit is not actually moved if the pursuer rolls higher - you simply remove it from play there and then. Therefore you don't have to worry what happens to it as it is destroyed and then you get to pursue into a new enemy
