8th Ed. Tournament Army
Discussion in 'Lizardmen Discussion' started by Minibem, Jan 10, 2011.
  1. Minibem
    Minibem New Member
    HI guys,
    I have a tournament coming up at the end of Jan and have put together an army list that I have played with a few times but any advice would be helpful as haven't been playing with lizardmen for too long
    SKink priest
    Stegadon with Engine of the gods
    Ancient stegadon
    2 x 20 squads of saurus worrios
    1 x saurus oldblood on coldone
    Slann mage priest
    1 2 squad of ten skinks (he is in this squd just to give him some protection
    7 x skink skrimishers
    1 x razadon
    1 x salamander
    Not big on models on the board i know for a 1250 army. Saurus I am using in 4 ranks of 5
    Any ideas welcome
    Thanks
    Bell
  2. Hiv0r
    Hiv0r New Member
    There is no way that is 1250 points.
    It looks VERY over the top in terms of toys.
    I don't think you can have 7x Skink skirmishers did you mean chamo skinks?
    This also should probably go in the army list part of the forum
  3. Sao
    Sao New Member
    Its a 2000pts army
    And when posting an army what have you given each unit, commands, magic items etc
    Just means the forum and give you constructive critism
    and if you want an example of a 2000pts list and how to present it it should look like this (advertisment of my list :D )
    http://www.lustria-online.com/threads/2000pts-give-opinions.5870/
    Just some tips :)
    ask any questions you may have
    Lloyd
  4. mixer86
    mixer86 New Member
    as already said it has to be more than 1250 for a number of reasons:
    1- you can't field a slaan in an army less than 1500 points due to max points allowed for lords (25% of army total)
    2- to field both a slaan and an oldblood your army would have to be at least 2000 points, but to give them equipment probably more like 2500 for the same reason as 1.
    3- to field a preist with steg and EOTG, again at least 2000 points.
    4- i have NEVER seen a slaan have skinks as the unit he joins, but ok
    5- unless they are chameleon skinks, skirmishers have a minimum unit size of 10 i think, pretty sure anyway
    Take a look in army lists to see how most write a list on here, do that and it will be much easier for us to help you out.
    Yours aye
    Mixer
  5. Batu
    Batu New Member
    I loaded your army (as listed) into army builder. You are NOT at 1250pts.
    With out ANY magic on the SLANN, OB, PRIEST your points are 1525.
    You are at 450pts for Lords and 312 are allowed @ 1250
    You are at 355pts for Heros and 312 are allowed @ 1250
    Skink Skirmishers must be at 10 unless your running Chams. (I loaded them as regular skinks)
    If you are running 7 chams your points would be 1539. (NOT INCLUDING MAGIC for lords/hero)
    You need to review the armies posted and redo your list and repost it.
  6. mixer86
    mixer86 New Member
    Actually Batu, i make it 1834, he has an ancient steg as well as the one for the preist as i read it, so 1734 give or take, don't have my army book at hand.
    Based on that you could make a 1850 list: meaning 25% limit= 462.5 points
    Therefore based on current list, taking the 7 skinks as chameleons:p
    Lords- 420 - can't be more than 462.5
    Heroes- 355 - can't be more than 462.5
    Core- 540 - must be at least 462.5
    Special- 84
    Rare- 435- can't be more than 462.5
    Total (approx)- 1834
    This legally would work as it is, enough core (just) and within limits for lords, heroes and rare. Problem is this is without ANY equipment for ANYBODY, not even command groups for the saurus.
    Also what you would have to do is make the razordon and sally either both sally or both razordon because for armies less than 2k i believe you can only have 2 rare choices, which would be the ancient steg and a razor OR sally hunting pack consisting of 2 monsters and 6 handlers. Can someone confirm that please?
    Based on the fact you ARE going to want equipment, i'd look at making it 2k minimum, or to kit them out better, 2.5k.
    Oh and to be completely accurate, the preists steg must be an ancient steg to carry the EOTG.
    Hope this helps
    Yours aye
    Mixer
  7. Minibem
    Minibem New Member
    hey guys,
    Sorry have been away for a few days so have seen your posts but have not been able to get my hands on my list. The biggest mistake I made was that it is a 2200 army! Here is my list with everything included
    Slann Mage Priest
    (battle standard bearer)
    Higher state of conciousness
    Focus of Mystery
    The Becalming cogitation
    Divine Plaque of Protection
    Dispel Scroll
    Lvl 2
    Engine of the Gods
    Saurus Scar Vet
    Light Armour
    Shield
    Sword of Hornet
    Carnosaur Pendant
    10 x skinks
    (musician)
    2 x 20 saurus warriors
    (full command in each squad)
    8 x skink skirmishers
    3 x terradon riders
    1 x Ancient Stegadon
    1 x razadon
    1 x salamander
    As I worked it out after all this I had 36 points spare. I normally put the slann in the squad of skinks. I know that this sounds bad but he is crap in combat and i wanted to give him at least a look out sir!
    Let me know what you think
    Thanks
    Bell
  8. mixer86
    mixer86 New Member
    when you say " 8 skink skirmishers" do you mean chameleon skinks or normal skinks.
    If u mean chameleons its ok but normal skinks have a minimum unit size of 10.
    also you might be over the points limit for your heros. maybe :(
    Yours aye
    Mixer
  9. Minibem
    Minibem New Member
    Hey Mixer,
    I mean 8 chameleon skinks! I'll double check my hero
    thanks
    Bell
  10. mixer86
    mixer86 New Member
    i haven't got my book to hand but had a quick add up of what i think the points are and i thought you were over by a little bit.
    Could be wrong though
    Yours Aye
    Mixer
  11. Sao
    Sao New Member
    Both his lord and heros are in % allowence.
    And if your slann has HSoC just shove him 3 inches from your saurus units.
    He will benefit from a 4+ Look out sir
    Then he is ethreal (sp?)
    And has a 2+ ward vs shouting people (can you tell I'm deffinately not a IG player :D )
    Trust me he is fine :D
    Lloyd
  12. Minibem
    Minibem New Member
    Thanks guys. I have submitted my army list so now just have to get everything painted!
    Will let you know how it goes!
