TOW Troglodon
Mikebiazzo
Member
Messages
31
Likes Received
11
Trophy Points
8
Hi folks,
My question is: if my troglodon achieve to roar succesfully, giving furious charge to my units, what would happen with multiple profiles like estegadon or cold ones? Each of the 5 skinks would have the rule too? In the case of the cavalry, would it the same for the mounts?
Thanks no advance!
Ok so those units have the split profile rule. I would say it affects riders, mounts and crew.
Cavalry:
"Unless noted otherwise, any special rules that apply to one element (rider or mount)
apply to the other as well."
Stegadon Howdah rule uses chariot split profile:
"Unless noted otherwise, any special rules that apply to one element (chariot, crew or beasts) apply to the others as well"
Thanks! Well, it's 6 more attacks to the stegadon. Well, the entire group. It can maje the difference I suppose.
Leadership 8 test is 3/4 possibility only, only if you charge and with reduce inches.......potentially distructive but not so easy to play it well (unfortunately)
Back
Top
