7th Ed. Up to 1250 points.
Discussion in 'Lizardmen Army Lists' started by Tepic, Jun 11, 2009.
  1. Tepic
    Tepic New Member
    This is the list I have so far. It comes to 1183 points and includes all the models I own!
    Saurus Scar-Veteran (1#, 140 Pts)
    1 Saurus Scar-Veteran @ 140 Pts
    General; Hand Weapon; Light Armour; Scaly Skin
    1 Burning Blade of Chotec @ [20] Pts
    1 The Maiming Shield @ [30] Pts
    Skink Priest (1#, 140 Pts)
    1 Skink Priest @ 140 Pts
    Level 2 Upgrade; Hand Weapon; Aquatic
    1 Staff of Sorcery @ [40] Pts
    Saurus Warriors (16#, 222 Pts)
    15 Saurus Warriors @ 222 Pts
    Musician Mus; Standard Bearer Std; Hand Weapon; Spear; Shield; Scaly Skin
    1 Saurus Champion @ [24] Pts
    Saurus Warriors (12#, 174 Pts)
    11 Saurus Warriors @ 174 Pts
    Saurus Warriors
    (12#, 162 Pts)
    11 Saurus Warriors @ 162 Pts
    Musician Mus; Standard Bearer Std; Hand Weapon; Shield; Scaly Skin
    1 Saurus Champion @ [23] Pts
    Hand Weapon; Shield
    Cold One Cavalry (8#, 345 Pts)
    7 Cold One Cavalry @ 345 Pts
    1 Cold One Rider Champion @ [55] Pts
    1 Jaguar Standard @ [25] Pts
    8 Cold One @ [0] Pts
    Causes Fear; Stupid
    I will be playing against Dark Elves and Tomb Kings. How can I improve the list?
  2. Caneghem
    Caneghem New Member
    First, and I'm sure others will point this out, but don't post point costs for each individual thing... and there's no need to put down all the hand weapons and special rules... as anyone commenting on your list will be well aware of what everything does.
    If you're making a 1250 list and you are already using every model you own.. it is going to be hard to tweak things. You've got some saurus, but they are unsupported and very slow.. so they will fare well against TK but not dark elves. You are at a point level where I'd say a unit of 3 or 4 terradons becomes an invaluable support unit. Failing that, get skinks of some variety. Skirmishers and the cohorts are both excellent and affordable. Drop the more expensive unit of 12 warriors and you could field 2 x 10 cohorts plus a unit of 10 skirmishers. Pare down the cold one unit to 5 and lose the champion, get rid of the standard etc.. and you should have room for some terradons.
    Get a salamander with extra handler in there too... might as well use up that rare slot! They can provide some panic and kills against armored things, and even fare ok in combat against light threats. Your army could be much bigger is I guess what I'm saying... Lizardmen can't win on saurus alone!
  3. Skeletmen
    Skeletmen New Member
    Drop the staff of sorcery, the priest doesn't need it. Give him instead a diadem of power and a dispell scroll. This way you have more dispell dice. You are going to need them against Dark Elves an Tomb Kings!
