I'm changing my list after doing pretty well in the last TOS and want to try something different. Any thoughts on the following list? Frog with no 6's, loremaster, free power dice and etherial. BSB, Crown of Command and Standard of Discipline Skink priest on Ancient Steg with Cube of Darkness 24x Saurus Warriors with full command 10 x Skinks 10x skinks 10x skinks 4x Krox with Champion 5 x Camo 5 x Camo Sally Sally 3 x Terradons
Very... how you say... unconventional. Lore of Beasts on the Frog?? (jk) Should be interesting. Solo Krox units aren't that common nowadays. It'll probably scare your opponents if they aren't used to seeing them, haha.
was thinking Life or Beasts. I see this very much as a grind army. I know you don't see many Krox on their own anymore but couldn't really work out why. Is there terribleness i'm not seeing? Read a post on the Khemri forum about running MI 1 wide and limiting the enemies combat res to 3 because they can only attack the champion, then you get 6 attacks (7 if the champ doesn't die) plus stomp back wanted to try it out... Any other advice would be welcome, as it is, as you say...unconventional(!)
