AoS Wanting to start Seraphon.
Discussion in 'Seraphon Discussion' started by Anastobe, Jan 20, 2019.
  1. Anastobe
    Anastobe New Member
    So I am looking to start a Seraphon army. Everyone loves dinosaurs right.
    My FLGS is pretty competitive, a lot of tournement lists for even casual games. Can anyone set me in the right direction of what I should acquire. I know summoning is strong but I'm not sure what I need. Thanks in advance. And sorry if this has been asked a million times already.
  2. Jatipower
    Jatipower Member
    If you can buy the battleforce... it is sooooo worthy. Slann is a must and the astrolith bearer
    Koriialstraz and LizardWizard like this.
  3. GuaDan
    GuaDan Well-Known Member
    Hi, welcome to our forum!
    The seraphon battleforce Starclaw Strike host is the best starting point, giving you skinks, skink Starpriest, troglodon/carnosaur, 6 flying units (i suggest 6 ripperdactyls) and a bastiladon.
    Then, you need to choose the point level you want to play.
    At 1k Seraphon have brutal lists based on the Shadowstrike Starhost, for which the battleforce provides an extremely good starting point.
    I would invest in Slann, Razordon, Astrolith bearer (or convert it from some saurus), more skinks and at least a couple of Engine of the Gods.
    Shadowstrike is still very effective in high point games, where you usually need some summoning support however.
    Other competitive battalions we have access to are Thunder quake starhost, based on big dinos, Fangs of Sotek, based on Saurus Warriors hordes, and Dracothion's tail, based on Saurus Knights.
    If you prefer the last two battalions you should invest in a couple of Start Coollecting Seraphon boxes and follow the precious guide posted here on Lustria Online.
  4. Starchief
    Starchief New Member
    Hi I am new to the forum too and I would either start with seraphon too.
    What's the better way to start.
    2 boxes of the start collecting the or the battleforce box. And what I need than too.
    A slann priest?
  5. Jatipower
    Jatipower Member
    It is better the battleforce but the start collecting if you want saurus army is wonderful. Slann is essential because he is the principal summoning tool and the engine of gods is very important too
  6. GuaDan
    I think the battleforce is a better starting point as it allows very competitive building right off and saves almost 50% money.
    Other units you might want regardless of what you start with are
    Engine of the Gods
    Razordons
    Saurus Astrolith Bearer
    MORE SKINKS.
  7. Starchief
    So if I want a saurus army I should go with the start collecting Box 2 of them an a engine of the gods. Is that a good choice ?
  8. GuaDan
    It depends on how competitive you want to be.
    Bear in mind that Saurus heavy list are only reliable at around 2k in matched play, with the Fangs of Sotek or Dracothion's Tail battalions, and that you would still skinks and other units to summon.
    Fangs of Sotek needs at least 60 Saurus Warriorsw to be competitve.
  9. Starchief
    Oh okay. So it is the better way to start with the battleforce box. I understand. So I will go with it the battletome and what ?
    I ve the money for this and 30 bucks.
    So I choose a skink star priest or another skink box
  10. GuaDan
    Currently I don't think the battletome is worth it, it is too outdated.
    You already have a Skink Starpriest in the battleforce.
  11. Starchief
    OK Oh man. So many options
    OK the battleforce box
    A skink star priest
    And a skink box extra
    So?
  12. Skorp
    Skorp Active Member
    Battleforce + Slann is the way to go. No question, you wont regret it. After that is up to you.
    GuaDan likes this.
  13. Anastobe
    Anastobe New Member
    I planned on picking up the battleforce box aswell.
    So I will also need a slann, Astrolith Bearer, engine of the gods 1 or more, more skinks (what's a good number?), and is it better to go with cogs or the vortex or both? Did I miss anything?
  14. Cinnabar
    Cinnabar Member
    You might want to hurry up on that Battleforce. I believe it may be sold out in some regions.
  15. Anastobe
    Anastobe New Member
    Would it be worth it to get two of them? Or is there too much overlap
  16. Shadowstorm
    Shadowstorm New Member
    2 boxes gets you 2 star priests, 2 bastis, 2 trog/carnos, 12 rippers and 48 skinks. Which isnt actually a bad start, the only thing you have too many of are the priests and rippers
    Contents breakdown:
    Priests: kinda only need 1 but a second doesn't hurt, either use the 2nd as a regular priest or just have him as a spare
    Basti: both versions are good for different situations, so you've got both.
    Trog/ Carno: either build multiple carnos (theyre so good you prob want more than 1) or build 1 trog + 1 carno for the variety
    Rippers: only really need 6 max for one unit but this either gives 2 units of 6 or makes the 2nd 6 up as terros
    Skinks: though 48 is too many for 1 unit (prob want 30-35 a unit) gives you either a head start on a second unit or some conversion fodder.
