Weapon swaps?
Discussion in 'Painting and Converting' started by Wildcard, Apr 27, 2011.
  1. Wildcard
    Wildcard New Member
    Hi,
    Has anyone tried swapping weapons/shields from right-hand to left-hand with lizardmen?
    What problems did you encounter?
    What advice could you offer someone planning on doing this?
  2. Lord Tsunami
    Lord Tsunami Member
    only problem i can see is that the right hand is usually a bit bigger, since it its modeled to hold a quite big shaft in it. the left hand might look a bit small since it has nothing in it. other than that i cant forsee any problems really.
    oh, and the shields will be upside down :D
  3. asrodrig
    asrodrig New Member
    I don't think it's actually possible. Even if it were, like Tsunami said, you would have a backwards/upside down shield.
  4. Wildcard
    Wildcard New Member
    The shields I can sort out, main question is will there be enough arm left or am I sculpting them.
  5. n810
    Actually you could do it with a backwards shield...
    (right side out but pointy bit facing backward)
  6. Lord Tsunami
    Lord Tsunami Member
    what do you mean? you wouldnt have to chop any part of the arm off, would you? :D
  7. n810
    saurus wariors come with seperate left arms and shields, if thats what you are worying about.
