8th Ed. What should I add to my lizardman army
Discussion in 'Lizardmen Discussion' started by Cacatron, Jan 11, 2012.
  1. Cacatron
    Cacatron New Member
    So far. I have 1 unit of saurus, 1 of skinks, 1 of cold one riders, a teredon rider, a stegedon with great bow, a slann and krock gar and his carnesaw , any suggestions for bulking out this army?
  2. Arli
    Arli Moderator Staff Member
    That is a nice start. What you should do is determine what kind of force you want to go with. The Slann and old blood on carnosaur (Kroq Gar) will only be used in games over 1000pts (for the Slann) and 1500 points for the old blood. You could convert the stegadon (if you have the pieces still) to be an engine of the gods using a priest model. In order to use the terradons, you will need two more of those.
    As far as the core goes, you need more saurus and more skinks. Each to your personal preference. You may also want to pick up some temple guard (to go with the Slann). You also need some salamanders and some chameleons.
    Hope this helps.
