8th Ed. When should Lizardmen use hordes in 8th?
Discussion in 'Lizardmen Tactics' started by Scalenex, Jun 19, 2011.
  1. Scalenex
    I'm thinking rarely. Saurus Warriors have such wide bases that a frontage of 10 would be wasteful in most cases. Skinks are pretty weak for major combat. Kroxigors are pricey for fieilding units of 18 or more.
    What say the rest of you guys?
  2. Elmquasmash
    Elmquasmash New Member
    Well, in a large battle a horde of Saurus would be fine as the battlefield will be larger and have more space (in most cases) and as for skinks, the most common horde I have seen is a Skrox unit.. You can go four Krox wide or three and then put two files of skinks on both flanks of the unit to make it ten wide.. Its not as pricey as a Saurus horde but it also lacks the staying power.. As you said, you will see hordes in our army pretty rarely ;)
  3. Benny6Toes
    Benny6Toes New Member
    Rarely? really? I love running saurus hordes. 30-40 Saurus 10-wide is fun to watch (i've done up to 60 just to try it). It's expensive for a single unit though, and it can be difficult to get it across the battlefield and into base-to-base contact.
  4. strewart
    I agree, pretty much never. They are 250mm across, if you are fighting a horde on 20mm bases you will just get the whole unit into contact going corner to corner. Anything smaller and you are wasting attacks. And people will not want an entire horde of saurus hitting their units, so they will reform to be thinner, or avoid your unit, or shoot your unit. Saurus are a bit too slow to force their way into combat.
    I think 6 wide is good for them. And yes, skinks in a horde... Well, could work but they're probably not even worth taking in units that big.
  5. Leokill27
    Leokill27 New Member
    I actually played 1500 against tomb kings a while ago with a horde of 50 Saurus, an oldblood in with them, a salamander and a bunch of skinks.
    I sat back and took the shooting with barely a scratch, he got itchy ( as he tends to) and came at me. I managed to get the charge and literally overran into his entire army 1 unit at a time
    I think they can work well, but you've gotta pick your opponent.
  6. Slaantastic
    Slaantastic New Member
    The thing overlooked in this topic is that Hordes are an excellent points denial tactic. I always bring a horde of 32 skinks + 4 Kroxigar into battle and, at 1500 point games, I stick a slann on the side of them with life. Toughness 6 skinks with 4+ regen plus wounds bein regenerated on the kroxigar for lore aspect? Priceless.
  7. L1qw1d
    L1qw1d New Member
    I hereby refuse to play poker with you. Ever.
    What about a horde o' skinks with some krox behind them?
  8. Coatl
    Coatl New Member
    thank you slaantastic. someone else who recognizes the beauty that is a big horde. big hordes might not be the most effective for maximizing your attacks in combat. they might be unwieldy and hard to move about. but they just...dont...die :) (used correctly of course).
    60 saurus, command and spears for 3k, thats my benchmark. ive lost the unit 1 time since 8th came out and that was due mainly to not knowing the steadfast reform rule. thats 750 pts (plus a slann of varying points cost) that i just dont have to worry about losing.
    people know i bring it, its common knowledge, its just so very hard to kill. and with the slann in the front with becalming cog, those #6 spells are just that much harder to get off.
  9. Leokill27
    Haha! Im not normally that mean XD
    Im still painting up my krox but as soon as I do I'm gonna have 6 of the bad boys running in as big a horde as I can play :D
  10. icecool208
    icecool208 New Member
    although i havent even played a game yet (stiil building my army) when I get a big enough army I'm going to put about 40 saurus w/ spears up against knights of the realm but im far from giving any good advice
  11. Leokill27
    I use a unit of 25 ranked up 5 wide against those knights, if you survive the charge (with the ranks you should stick about) you will destroy them :)
  12. icecool208
  13. FavoredoftheOldOnes
    FavoredoftheOldOnes Member
    I've always used 40-50 Saurus in horde formation since 8th edition. Most times they do great, others a little worse. I haven't tried not putting them in horde so maybe I will try that someday. You can't forget (as others have mentioned) that these guys will take forever to kill unless you do something really dumb with them (get charged by multiple units, on the flanks, etc.). This is just my opinion though and based mainly on play experience.
