Blog Aquilla reloaded, Marcus' 40k blog
Discussion in 'Painting and Converting' started by Lord-Marcus, Sep 13, 2018.
  1. Lord-Marcus
    Boom. Requesting thoughts. IMG_20181008_230803.jpg IMG_20181008_230811.jpg IMG_20181008_230820.jpg IMG_20181008_230827.jpg
    Warden, LizardWizard and Aginor like this.
  2. Aginor
    Still not a huge fan of the blue parts but otherwise they look pretty good.
  3. Lord-Marcus
    I used blue to simulate tinted glass
  4. Aginor
    Yeah I know, it is just... I don't know. Too solid maybe? Too strong? I would probably have tried painting the glasses white or light grey and then use a thinned down blue glaze to achieve that effect.
  5. Lord-Marcus
    Good point. I may revamp it. Have not yet decided.
    Working on
    More of em
  6. LizardWizard
    I like the yellow jackets. They really pop.
    Your browns all blend together a bit. Perhaps an addition middle step of reapplying your base coast as a layer between your shad/wash step and your highlighting might preserve some of the sculpts details.
    @Aginor had great advice on the lenses. If you watch this there is some solid advice as well.
    Aginor likes this.
  7. Lord-Marcus
    Currently:
  8. LizardWizard
    Lenses are looking good.
    Aginor likes this.
  9. Lord-Marcus
    Thanks mate. more to come.
    Sidenote: great username.
    Aginor and LizardWizard like this.
  10. Aginor
    Yep, those are a lot better. :)
  11. Lord-Marcus
    Probably going to do a light blue wash on them to bring them out a bit.
    Also:
    Going to finish the squad this week, although I'm currently blasting through a dungeon terrain commission.
    After this, I have another squad of each feudal and steel legion, a couple squads of Mantic gcps.
    I also have some conversions in mind for landsknect
  12. Aginor
    If you have gloss varnish you could also apply a thin layer of that, that would make them shine a bit.
  13. Crowsfoot
    With the lenses apply a thin short white diagonal line to represent relection, go top to bottom but don't go the full length.
    NIGHTBRINGER, Aginor and LizardWizard like this.
  14. Lord-Marcus
    Will do when I get home
    @Aginor now that you mention it, I do have 'ardcoat. I was going to Varnish these guys with my matte varnish though. You think putting ardcoat over the mat varnish would screw anything up?
  15. Crowsfoot
    As long as the first coat is dry it won't do anything apart from changing the gloss level.
  16. Aginor
    Yep that should work.
  17. LizardWizard
    You can also use interrupted diagonal lines or parallel lines. I recommend trying a few different passes on scratch paper if you are really particular.
  18. Lord-Marcus
    Awesome. Will do. Any specific tips when using Ard coat?
    Also, next planned guard variation: landsknechts with bionics and las-arbeques
  19. LizardWizard
    Don't overwork it. Apply a thin layer and try not to move it around too much.
  20. Lord-Marcus
    And brush care?
