Blog Beastie's Lizardmen
Discussion in 'Personal Paint Logs' started by Beastie, Mar 1, 2017.
  1. Jorgik
    Jorgik Well-Known Member
    :wideyed:X10^of a million
    Ritual and Bowser like this.
  2. Beastie
    Beastie Active Member
    After almost half a year since my last post, I'm proud to present finished Scar-Veteran on Cold One. I'm going to put gloss varnish on gems and maybe dirt to make it look wet. Base is very simple, I may add some bits or water effect in future (but i'm not certain yet).
    I finished it last week. Enjoy ;)
  3. n810
    Wow he came out amazing. :eek:
    Ritual, Warden and Beastie like this.
  4. tom ndege
    Excellent job! And great use of the old shield... really like it!
    That is some mighty fine painting. It turned out amazing. How did you get the scales on the cold one to turn out so well?
  6. Lord-Marcus
    good use of the dark elf cold one.
  7. Beastie
    If you take a closer look, you can see that every scale was lined using grey and white, sometimes i just glazed the highlight. White as a ending color is great when opposed by black as maincolor. You get the high-contrast look. And it's not that hard, just daunting ;) Also, blueish scales make the scheme more interesting. It's actually a Venomhide Ravasaur scheme from WoW, which i used to play a lot back in the old days when i got the time.
    I'm amazed how much you guys love it, i just wish i had more time to finish some other Lizardmen from my force to share. But I'll continue to share some pictures as soon as i get something wip/done.
    As for the photos, i'm doing them at home, previous skins where photographed at my workplace, which should explain the quality difference ;)
    Ritual, Warden and NIGHTBRINGER like this.
    What is the key to the placement of the white? Does it go over a subsection of the grey line?
    It looks gorgeous. It should be no surprise at all; you did a fantastic job.
    Beastie and Ritual like this.
  9. Beastie
    Yes, it goes over grey as a 2nd grade of lining.
  10. Warden
    Wow that is amazing! What is that greenish-head trophy on the side, it looks like the saurus hacked off the head of a cave troll!
    Does the white go all the way around the scale, or just at specific sections (top, bottom, etc.)?
  12. Beastie
    It's a head of a Crypt Horror from Vargheist/ Crypt Flayers set.
    Just the specific section, in this example i tried to stick to the bottom.
  13. Aginor
    Amazing!
  14. Crowsfoot
    Very nice indeed, I love the gems looks like you started with a black base coat which is they way I do them and find it gives good results, the scales are excellent and really do bring the model to life, the crypt horror head is a great touch.
    Love it ;)
  15. Beastie
    Small update: I'm alive and found some time to fix my old Oxyotl. Also, saurus alpha happened.
  16. Aginor
    Great highlights on that Saurus!
    Beastie likes this.
  17. tom ndege
    And nice blow pipe... quite close to the original ... what did you use for the middle part?
  18. Beastie
    It's the middle section from giant blowpipe from stegadon kit.
    Anyway, I even got the time for some other heroes: 5th Ed. Tehenhauin I'm going to use as a Starpriest, and Skink Chief. Hope you like the Chief as much as I do ;)
    Crowsfoot, Warden and tom ndege like this.
  19. Beastie
    Starpriest done ;-)
  20. Crowsfoot
    Nice banner ;)
    Beastie likes this.
