Blog Canas' armies
Discussion in 'Painting and Converting' started by Canas, Mar 6, 2018.
Tags:
  1. Killer Angel
    they basically have the same role. Fluff-wise, the tech-marines are trained by the AdMech so they can keep in good condition the precious vehicles that Mars gives to the SM.
    The Iron Hands chapter, being so fixed with tech bioengineering and limb replacement with mechanical parts, got a strict tie with AdMech (so fluff-wise that would be the best choise).
    Canas likes this.
  2. Canas
    The first unit of necrons from the forgebane box. They were surprisingly easy to paint.
    Also, a hill, cuz I need terrain
    WP_20190205_12_00_00_Pro.jpg WP_20190205_11_59_53_Pro.jpg WP_20190205_12_00_18_Pro.jpg WP_20190205_11_59_43_Pro.jpg
  3. Warden
    Nice looking necrons!
  4. Canas
    And more necrons, the lichguard this time.
  5. Aginor
    This is going to be a nice looking army. :)
    LizardWizard and Canas like this.
  6. Canas
    A techpriest ensigneer, and a larger piece of terrain with water coming out of a damaged portal realmgate thing The terrain is considerably less shiny, but my phone's camera apparently catches all the light.
    WP_20190215_12_48_49_Pro.jpg WP_20190215_12_48_55_Pro.jpg WP_20190215_12_49_19_Pro.jpg WP_20190215_12_50_00_Pro.jpg WP_20190215_12_49_11_Pro.jpg WP_20190215_12_49_34_Pro.jpg
    Lizerd, Cageyblood, Crowsfoot and 2 others like this.
  7. LizardWizard
    Looking Good. The Necro and new Tech Priest look like nice and tidy!
    Canas likes this.
  8. Canas
    And the cryptec and his wraiths for my lil necron force. I like his staff thing.
  9. LizardWizard
    Looking good. The staff turned out nice.
    Dark green was a good choice for the colored armor plates. It is still very Necro without being the same as all the other armies i see. Adding a bit of yellow glaze could help to make some of the highlights pop more.
    If you blackline the recesses for their tails it would help to define the individual plates of metal.
    Lizerd likes this.
  10. Canas
    Picking up the highlights with my camera is quite difficult without just zooming in so much you start seeing individual brushstrokes and more importantly every single mistake I made. The highlights are more pronounced in reality. But I'l try a yellow glaze if I ever make another batch of necrons. Used a green one this time but that might have been too close to the armour plates green to really pop out.
    Same for their tailplates. The nuln oil is enough for the most part, but my camera just doesn't really pick it up. Though I like how the lines on the recesses in the armour plates make the armour pop out more so I'l try that as well.
  11. Canas
    Continuing with the nighthaunt again now that the 40K stuff is done.
    Lizerd, Crowsfoot and Aginor like this.
  12. Aginor
    I really like those models, but man they look fragile as hell.
    Lizerd and Crowsfoot like this.
  13. Canas
    These aren't too bad, the bit of plastic they lean on is quite thick. But you should look at the spirit torment, he just connects with 1 thin sliver of plastic to the base.
  14. LizardWizard
    Their wrist are also tiny and support huge weapons in most cases.
  15. Canas
    I made some more terrain, this time something that is a bit taller in the form of some rock formation.
    WP_20190305_15_55_59_Pro.jpg WP_20190305_15_56_07_Pro.jpg WP_20190305_15_56_22_Pro.jpg
    Lizerd, Imrahil, Cageyblood and 4 others like this.
  16. Canas
    Some banshee's, they look a bit better than the other nighthaunt I think. Though I still have no clue how to paint the newer models.
    WP_20190307_15_42_58_Pro.jpg WP_20190307_15_42_49_Pro.jpg WP_20190307_15_43_10_Pro.jpg
    Lizerd, Aginor, LizardWizard and 2 others like this.
  17. Crowsfoot
    Just a tad heavy with the Shade.
    Remember less is more with shades and glazes, GW shades don't look like they do much when wet but once dry they can have a dramatic effect on your models, you can always add another coat if it's not dark enough.
    What do you mean you don't have a clue? scheme choice?
  18. LizardWizard
    Take is slow with the shade. It is better to apply too little and then have to apply an additional coat than to frost the mini.
  19. Canas
    The reason it's so much is cuz the base is the technical nighthaunt blue paint. I've not quite figured out how you're supposed to paint with that one yet and it ends up either barely noticeable or one layer immeadiatly turns the entire thing blue (or green if I use the other one).
    And I can't really figure out how to paint the various ghosts. I painted some spectral hosts earlier where I basicly just some shade at it which worked well due to how many ridges there are on those models making for some natural highlights and stuff even with the models basicly only being 1 or two colours. However, the newer nighthaunt models don't have as many ridges. In fact they're mostly just flat monochrome Surfaces, with very few other objects (trinkets, helmets etc.) to highlight or contrast the larger monochrome Surfaces of their cloaks. So so far those newer models mostly end up looking like 1 big blue (or purple, or black, or white) blob. The banshees are some of the better ones simply cuz they come on a fancier base so there's some stuff below em for contrast, plus they have at least some ridges and such in their cloaks and skirts and whatnot.
  20. Aginor
    Don't tell my buddy but that's how I feel about those new technical colors on his Nighthaunt models as well.
    Sure they are easy to use but... I don't actually like how they look that much.
    IMO they would profit from a bright drybrush to give them more structure and contrast.
