AoS Crazy Lists and weird ideas
Discussion in 'Seraphon Army Lists' started by Killer Angel, Sep 20, 2019.
  1. Erta Wanderer
    hit reply on the bottom right. yes it's only the battalion but thats healing on 5 units isted of 1 and you don't have to roll for saves and you reroll wounds
  2. TheGreatDerpyOne
    TheGreatDerpyOne Member
    And I'd have to scrap my entire army & strategy because even the minimum point cost for this is too expensive, so thank you - but I'll keep it as it is currently.
    I'll keep the strategy in mind if I want to make a drastic change.
    (EotG looks pretty bad stats wise unless you keep it close to your slann to pick between buffs)
    (With this change I'd lose one of my assassination tactics and have no use for command points)
    (thanks to GW for making batallions do this stuff - that makes my army a variant of the basic cookie cutout Seraphon recipe - whilst my entire point was to be unique)
    (for what I've read, that batallion is strong, but you'd have to pick between the benefits, so it may still work with priests)
    EDIT: So I opened up the online free warscroll builder, made a thunderquack duckhost (kroxigors are the better alternative, change my mind) so let's see.
    Pick savage every turn to get the rerolls on everything except hits
    Add astrolith for rerolling hits
    the astrolith and engine have synergy with a slann
    add balewind and cogs for summoning
    battleline = 2 sets of 5 knights and as many skinks as point value will allow for
    2k points cookie cutout thunderthighs
    aaaaaand I'm not having fun anymore.
    delete list.
    (Kroxies have 4 wounds a pop, which makes killing them harder and healing them more effective - besides, they CAN have a better damage output than <equal points> worth of razors& handlers - which I believe is 2 - but my point is because of their survivability, and because the cookie comes with a summoning setup, you can just spawn in razors without paying points for them and have them safe behind a cow wall of 2 basties and 3 kroxies, they'll still benefit from the reroll hits, won't need the heals, and are more convenient to get this way)
  3. TheGreatDerpyOne
    Ok, here's a doozy - probably won't work, but fun nonetheless.
    Edit: Well then - I've scrapped most of the CP list design after some research, and THIS is now my crazy CP list
    ______________________________________________________________
    Kroak (430) (General)- Edit: Kroak can't have command traits, hmm...
    *Rolls 3 dice in each of my hero phases - every 4+ is an extra CP
    *Can summon support units like skinks to take points after the carnosaurs are done trampling everything
    *Moves himself using LoSaT despite being on a balewind
    Oldblood on carnosaur (240) - Crystalline blade (Hysh)
    *Pick a melee weapon and add 1 to its wound rolls.
    Oldblood on carnosaur (240) - Aetherquartz Brooch (Hysh)
    *Roll when spending a CP - on a 5+ you get it back, recycling is important to this strategy and to the environment!
    *Since you roll when spending one, you can then decide to instantly reuse that CP on another trigger of the ability.
    Oldblood on carnosaur (240) - No artefact
    (this one charges in first to try and lure out the counterattacks)
    (keep in mind that these Oldbloods do an AOE buff on each other - 1CP = 6 extra attacks in the combat phase)
    (Since we can't buff their ranged attacks, I suggest we just keep barraging the same hero target repeatedly)
    Saurus Astrolith Bearer (160)
    *Making sure to reroll any failed hits for the massive amount of Dino Waagh we're about to commit
    *He can run every turn as we won't be needing him in combat, really.
    Eternity guard Batallion (150)
    (3x 5 saurus guard = battleline = 240)
    Eternity warden
    (140)
    *Adds an extra CP to start with, makes setup faster, and is a good defensive squadron
    Extra Command Point (50)
    *Shouldn't need an explaination
    10 Skinks (70)
    Balewind Vortex (40)
    Kroak can teleport anyways, might as well give him another spell.
    2000/2000Pt. 7 turn Deployment
    If there's a way to make these carnosaurs attack twice - PLEASE tell me - as their buff lasts until the next hero phase, if I can attack twice, they'll rip through anything.
  4. TheGreatDerpyOne
    I've decided summonspam is overdone, I'm doing some research on other broken strategies
    May Sotek guide you :p
  5. brodarg
    brodarg New Member
    My Magic & Mayhem List:
    Leaders:
    Slann Starmaster
    Lord Kroak
    Engine of the Gods
    Battleline:
    10 Skinks x3
    Behemoths:
    Dread Saurian
    Endless Spells:
    Balewind Vortex
    Chronomantic Cogs
    Burning Head
  6. MackiMac
    MackiMac Well-Known Member
    Kroak are sadly not allowed any command traits.
  7. Lizerd
    Lizerd Well-Known Member
    Basically the idea of this list is to be the biggest middle finger to anyone with heavy armor
    Allegiance: Seraphon
    Mortal Realm: Ulgu
    Leaders
    Slann Starmaster (260)
    - General
    - Trait: Great Rememberer
    - Spell: Stellar Tempest
    - Artefact: Betrayer's Crown
    Skink Starpriest (80)
    - Spell: Mystical Unforging
    Saurus Scar-Veteran on Carnosaur (240)
    - War Spear
    - Artefact: Sword of Judgement
    Battleline
    5 x Saurus Knights (80)
    - Lances
    - Lances
    - Lances
    Units
    3 x Salamanders (120)
    3 x Skink Handlers (40)
    Battalions
    Dracothion's Tail (80)
    Firelance Starhost (150)
    Endless Spells / Terrain / CPs
    Chronomantic Cogs (80)
    Total: 1990 / 2000
    Extra Command Points: 2
    Allies: 0 / 400
    Wounds: 108
  8. TheGreatDerpyOne
    Oh all right, no problem, list is still broken despite kroak's lack of command trait
  9. TheGreatDerpyOne
    I'd turn the salamanders into razordons because there's too many things that ignore rend, and salamanders' hit&wound chance is... saddening
    but hey, if it works it works
  10. Erta Wanderer
    it's a ok list if you spend 3 command points on the carnosaurs you can do
    per carno aganst a 4+ save or 0-8 damage against good saves like chaos warriors, stone horns, mortec guard, phoenix guard or witch elves and only if you keep all 3 of them within 12 of each other and the asttrolith
  11. Lizerd
    Razordons are definitely cool but they don’t have the same rend as salamanders. From personal experience I was able to get six salamanders rerolling hits to wipe out a unit of 20 ard boys in two rounds of shooting.
  12. Erta Wanderer
    really? dang that's exceptionally lucky
  13. Lizerd
    The whole game went poorly for the ork player (he was also new to AoS). He effectively cleared my saurus knight screen after they dealt a few mortal wounds to the orks. As soon as they cleared that line I fell back and created another screen of skinks, all the while being scorched by salamanders.
    In the meanwhile I also killed a Maw Krusha in one round of melee combat :D
  14. Erta Wanderer
    what on earth did you do that with? i don't think an entire seraphon army can do that. did you have 4+ carnos?
  15. Lizerd
    It did involve carnosaurs which is why I say they are still viable. So I had an oldblood on Carnosaur burn its command ability which in turn affected my scar vet on carnosaur. The scar vet had sword of judgement and a warspear. 8 attacks and 3 hits of 6. The maw krusha already had a few wounds on it from a round of salamander shooting. it took 10 mortal wounds in an instant :D
  16. Erta Wanderer
    oooh ok a sword of japan would do it
  17. ILKAIN
    ILKAIN Well-Known Member
    that is an epically hilarious typo
  18. Lizerd
    wHiLe yOu sTudiEd At SChOoL I sTUdiEd tHE BlAdE
  19. ILKAIN
    is that you? I feel like ive seen that photo before...
  20. Lizerd
    Nope, it’s definitely not me. I personally would use a Roman Spatha over some weeb katana
