AoS Engine of the Gods
Discussion in 'Seraphon Discussion' started by xoid, Mar 30, 2020.
  1. Canas
    The command ability can be used multiple times though. Which does give multiple EoTG some potential.
    Plus, seeing as we're swimming in command points anyway it doesn't require a very weird build.
    The only real problem I see with the build is that the EoTG takes up behemoth & hero slots & you kinda want to keep a slann nearby at least some of the EoTGs for maximum effect. But something like the following should be viable-ish (at least in casual play):
    - Thunder lizard subfaction
    Heroes:
    - Slann
    - 3x EoTG
    - Scar vet on carno
    - Starpriest
    Battleline:
    - 3x 5 saurus knights
    - 5 saurus guard
    Endless spells:
    - Bound Geminids
    - Bound lifeswarm
    Battalion:
    Firelance templehost
    CP: 1
    Artifacts: 2
    2000 Points exactly.
    Pick artifacts and spells and such as you prefer :p
    Move the slann, guard as one unit.
    Try to keep the slann within 12" of at least 1, but preferably 2 EoTG's
    Use Trove of the old one technology as much as possible, with 2.3 CP per turn on average (4 CP max per turn) it should be quite spammable resulting in 2-4 EoTG rolls per turn (and possibly some spare CP for your scar vet or slann)
    You have 4 behemoths to murder stuff with, don't be afraid to charge your EoTG's into the fray.
    The healing from lifeswarm and the EoTG, alongside scaly skin should help keep you alive
    Use geminids and the mortal wound spam from your EoTG's & slann to decimate opponents.
    Use the knights to hold objectives and function as speedbumps so you can send your behemoths into favourable engagements.
    Use whatever warriors you summon in a similar fashion.
    You could potentially drop the firelance battalion and get Kroak instead of a Slann (plus a 100 spare points).
    Probably not the best possible list, but it doesn't look terrible either. Also, ironically this might actually be one of our better lists when it comes to summoning. Plus, it definitly looks fun.
    Nart, Carnikang and Just A Skink like this.
  2. Just A Skink
    Or that could make your slann even more of a target?
  3. Slikus Vaw
    Slikus Vaw Active Member
    I don't think 3 would be all that effective, it's alot of points to be putting into that aspect of your army. The one getting 2 is very useful but the others it would be lackluster compared to what that one can do I would maybe go 2, 260 points for an EotG that activates only once isn't too appealing nd I think that's why we won't see them too often out of thunder lizard.
