AoS Fire Lance with extra Carnosaurs
Discussion in 'Seraphon Army Lists' started by Lizerd, Mar 16, 2020.
  1. Lizerd
    Lizerd Well-Known Member
    This list is a slight modification of the one @LizardWizard wrote for me, as the local meta has heavy emphasis on dealing out mortal wounds in large quantities, so here is the final product
    Allegiance: Seraphon
    Coalesced Koatl’sClaw
    Leaders
    Slann Starmaster (260)
    - Spell: Stellar Tempest
    Saurus Oldblood on Carnosaur (250)
    • General
    • Command Trait: Dominant Predator
    • Blade of Realities
    Saurus Scar-Veteran on Carnosaur (210)
    - War Spear
    - Eviscerating Blade
    - War Spear
    Skink Starpriest (120)
    - Spell: Claws of Glory
    - Spell: bind endless spell
    Battleline
    10 x Saurus Knights (200)
    - Lances
    - Lances
    - Lances
    10 x Skinks (60)
    Battalions
    Firelance Temple host(160)
    Total: 1990 / 2000
    Extra Command Points: 1
    Allies: 0 / 400
    Wounds: 121
    the idea is to have a lynchpin Oldblood with some skinks screening the Slann from enemy charges. Each carnosaur stays behind 10 saurus knights and is accompanied by a starpriest to pop his mortal wounds ability on the saurus knights as they put out a stupid number of attacks. The central “HQ” of the Oldblood, Slann, and skinks will be focused on holding the rear and generating command points. Speaking of command points this list is heavily based on command points, with the Oldblood popping multiple buffs such as all out attack or the koatls claw command ability. Thoughts and opinions are always welcome as they make these lists truly fine polished
    Captaniser, Womboski, Imrahil and 3 others like this.
  2. Jason839
    Jason839 Well-Known Member
    Needs a fourth carnosaur :D
    Imrahil and Lizerd like this.
  3. Lizerd
    Drop the Slann for another one?
  4. Jason839
    Naw probably not. You will want the command points he makes.
    Lizerd likes this.
  5. Lizerd
    Fitting in a fourth one is kinda difficult :( either I keep the cp generation or mortal wound output, I really can’t figure out which one.
    Actually solution! We can just use the list @LizardWizard wrote :D
    Womboski and LizardWizard like this.
  6. Shocksem
    Shocksem Active Member
    Drop a starpriest and upgrade that slann to a kroak?
    Womboski and Lizerd like this.
  7. Lizerd
    I was thinking dropping the skinks and Slann for kroak, as dropping a starpriest would leave me a fair amount of extra points, and it also means sacrificing serpent staff which is downright hilarious on a big unit of saurus knights
    Womboski likes this.
  8. Vallek
    Vallek Member
    I'll admit to not being super well versed with the new rules yet, however, how are you playing a Coalesced Army with a Firelance Starhost Battalion?
    Firelance Starhost specifically states it can be taken only in a Starborne army.
  9. Lizerd
    Good catch! I’m used to writing Star host out of sheer habit. So yes it is a temple host, I made a mistake
  10. Womboski
    Womboski Well-Known Member
    Let us know how it goes!
    Lizerd likes this.
  11. Lizerd
    I should be able to get a match this week, if not I can see what happens for Sunday
