AoS General's Handbook finally announced !!
Discussion in 'Seraphon Discussion' started by Seraphage, Jun 26, 2017.
  1. Aginor
    Oh and also:
    Saurus musician allows them to move double.
    That was the case all along wasn't it? Maybe that was changed to not counting as run?? Surely can't be! ....or is it?
    EDIT: In case you noticed: Yes, I am aksing all those questions on TGA as well to clarify, the guy who writes the above linked blog is active there, and maybe others who saw the stream.
  2. Seraphage
    Seraphage Well-Known Member
    10" move for infantry without running, seems not only broken but also silly to me :p
  3. Nukes4life
    Nukes4life Member
    saurus didnt change and the healing slann after dying is a trait
  4. Aginor
    So how many traits do we have to choose from for the Slann?
    I thought it was three, which would make one of those NOT a trait:
  5. Nukes4life
    Nukes4life Member
  6. darren watson
    darren watson Well-Known Member
    I hope it's both! Fair enough if it's a choice though. Both are really strong
    Captaniser likes this.
  7. Killer Angel
    I hope they'll fix the Ring of Immortality in the same way. As it is now, it's worthless.
    Captaniser and Aginor like this.
  8. Aginor
    absolutely!
  9. Aginor
    BUAHAHAHAHA!!!
    Just saw this on TGA and almost fell off my chair laughing. Pure gold! :'D
    In all honesty though: Our second Battletome was scrapped in favour of this, so we got the stuff we would otherwise have received, in this book. There should really be Seraphon on the cover.
    "Age of Skinkmar" made me chuckle though. :D
    Crowsfoot, Iskander, Freddy25 and 5 others like this.
  10. Kadanga
    Kadanga Active Member
    @Aginor The traits I included in my writeup was the ones the mentioned on the live stream (it's at around 1:12:00 on the 2h stream).
    The wound thing sounds like what they discussed for the ring of immortality, I cant recall hearing any of it in Seraphon regards. If anyone wants to rerun the stream to check if I missed/missheard anything, be my guest. Though I believe I was thorough :) (I re-listened to that part 7-8 times to get all the traits correctly).
    Aginor likes this.
  11. Kadanga
    I just relistened to the same part. The rerolls and knowing skink spells might be one trait. I havnt found the third mention yet tho.
    Aginor likes this.
  12. Aginor
    IMO that's the most logical option because otherwise one of the traits is (IMO at least) significantly weaker than the others. That way we basically have
    - one enhancing mobility
    - one enhancing spellcasting
    - one enhancing endurance
    which would be kinda logical to me, and all three are worthwile.
    Seraphage and darren watson like this.
  13. Aginor
    Btw here's a small list for 1000 points with the new system if I did the math correctly:
    Slann (general, spellcasting trait) - 260
    Priest - 80
    Starpriest - 80
    Troglodon - 180
    40 Skinks - 200
    40 Skinks - 200
    = 1000 points.
    Tactic:Go second and hug the corner. Then
    - change the ascendant constellation to "Hunter's steed" if you didn't roll it in the beginning
    - buff the Troggy with Serpent Staff, Mystic Shield, Celestial Rites, Curse of Fates, and Starlight
    - port the Troggy over to the enemy
    - Troggy shoots an enemy unit with a low save near your target (hopefully hitting, giving you +3" on the charge)
    - CHARGE! You have a good chance to make the charge, since you get +1" on charge, AND can re-roll it, and maybe even get the +3 from the spit. You can also use Curse of Fates and add another +1 to one of the Troggy's rolls in each phase, which makes the 6+ more likely for the wound, so you get awesome damage with the bite.
    If Troggy survives the first round you can either save it by teleporting it away, putting it behind your Skink wall, and then harass the enemy again in a later round, or you can let it fight on while moving your 80 Skinks toward the enemy, buff them, and shoot the living hell out of everything.
    The Slann's command ability ensures that you don't lose too many skinks by Battleshock.
    Could be a fun list for 1000, with a lot of wounds for the enemy to chew through, especially because wary fighters makes the Skinks more survivable.
  14. Kadanga
    Okay so I relistened to both videos and I was correct (sadly). Edit: Wait I'm not sorry, that relic is amazeballs!
    The incandescent thing is a relic. When they go through the list they say that the Slann has Masters of Intellect (bonus to casting) and the incandescent <something untellable containing a lot of ph and sh sounds>
    I'm gonna clean up the compilation post with this info.
    I also listened to the part regarding massive regiments, they say that infrantry are more likely to get massive regiments than ranged units. Just to clarify.
    Captaniser, Freddy25 and Aginor like this.
  15. Aginor
    Good job clearing that up!
  16. Aginor
    Sooooo.... that means we know at least one artefact now, that's also something positive! :)
    I wonder what the others are.
    For melee stuff we can pretty much use the Order artefacts (IIRC those are still legal to take if you play Seraphon allegiance, aren't they? I know it is that way with allegiance abilities but I am not 100% sure with artefacts). I hope there is an artefact for ranged combat, or for casting, or for improving saves, maybe even against mortal wounds, or maybe healing....
  17. Kadanga
    They touch upon it in miniwargamings review of GHB2017 (it's on youtube). I cant recall exactly, but some things are just the order ones with new names unfortunatly. But that Incandescent thingy seems really useful.
    Aginor likes this.
  18. Aginor
    Aw, that's a pity. Well, it can't ALL be great.
  19. Aginor
    Now that I think of it that artefact does pretty much exactly what I would expect when reading "Phoenix Stone", in contrast to what the actual Phoenix Stone does, because that one is only a healing thing.
    Freddy25 and Captaniser like this.
  20. Nielspeterdejong
    So any confirmation about that? The Slann has a Trait that lets him reroll spell and dispell rolls of 1, as well as him knowing the Skinks their spells?
