AoS GHB 2020 Predictions & Desires
Discussion in 'Seraphon Discussion' started by sigmonstar, Jun 28, 2020.
  1. Canas
    yup, they can force you say to only place your terrain in a corner. Even with the relaxed requirements for the placement of faction terrain.
    The more I think about this rule the worse it gets. It the whole premise of a rule like this where A is allowed to make the two options and B gets to choose which he gets is predicated on A & B wanting the same thing, so if A favours one side B will obviously pick that side leaving A with the "bad" option. But that only works if A & B want the same thing, and armies in warhammer are far too assymetrical for that to work. Without symmetrical needs this entire setup just falls apart.
  2. Putzfrau
    The new battleplans and overall rules tweaks are really nice. Been a big fan of those so far.
    Grotpunter, Imrahil and Krissey like this.
  3. Angela
    Angela New Member
    Does the GHB trump our battletome? Our battletome states that our RSE must be 6" away from objectives. I can't imagine my opponent is going to let me put it 1" from an objective. And why aren't these placement restrictions on the warscrolls, where it would be quick and easy to find?
  4. Killer Angel
    Yes, FAQ and publications more recent than the battletome, update and override it.
    Sometime it's a nerf, sometime it's a boost.
    Canas and Erta Wanderer like this.
  5. Angela
    Angela New Member
    I went back to the GHB 2020 and it reads "and more than one 1" from any objectives, in addition to any other restrictions that apply." So doesn't that mean that we still need to be 6" from the objective?
  6. sigmonstar
    sigmonstar Active Member
    seems like a redundant rule then. before ALL terrain needed to more than 6" from an objective if i remember correctly so this seems to be providing an exception for faction terrain, probably to give people like us and fyreslayers a bit more room in missions where there is more than one objective in your delpoyment zone.
  7. Canas
    The other restrictions refer to any specific restrictions set by the battleplan you're using. The default is now 1" to allow some of the bigger terrainpieces to actually be placeable on the table.
    ILKAIN and Killer Angel like this.
  8. xoid
    xoid Well-Known Member
    So I just got the GHB20 and am reading through it and another one of the coalesced abilities just got nerfed. Only half the games setup using the rules as written will use the terrain table that is covered by Primeval Domain.
    Just A Skink and Erta Wanderer like this.
  9. Canas
    well it's an achievement that they've managed to nerf it given how underwhelming it already was...
    Killer Angel likes this.
  10. Flo
    Flo Well-Known Member
    We still need to place 6" away
    The New GHB just has additional restrictions for All faction objectives (even for those who dont have a restriction on their warscroll or a smaller restriction)
  11. Grotpunter
    Grotpunter Well-Known Member
    Simple solution is just to say "no thanks" and randomize terrain and terrain effects. We still roll 2D6 where one determines if table A or B and the other which of the 6 effects.
  12. Killer Angel
    ATM my new GHB hasn't arrived. Could you post a pic of the exact rule?
  13. Flo
  14. Killer Angel
    As usual, unclear rules…
    You read it "this is the new general rule, unless the warscroll of the terrain got different rules"
    i read it as "this is the new rules for terrains, unless the are different rules for terrains in the scenario"
    If you are right, that would be truly weird...
    Erta Wanderer and Canas like this.
  15. Flo
    No its clear, it says "in addition to other restrictions" not "instead of other restrictions" this wording is for the terrain pieces who dont have a restriction or a lower restriction
  16. Killer Angel
    The point is: new rules override the ones already there. so, that rule should simply replace the "old" restriction of the terrain warscroll, and the "other restrictions" apply to something else.
    Erta Wanderer likes this.
  17. Canas
    No terrain warscroll has any restrictions. The only restriction came 1) from the scenario and 2) from the old GHB 19 book that stated the 6" distance. GHB 20 overrules GHB 19 so we now have a lesser restriction.
  18. Flo
    Thats why they say "additional", it overrides the rules with extra restrictions
    What bothers me more is something else, faction terrain is additional terrain to the 10 pieces
    And the wording clearly says Player A sets up the terrain
    So the battletome say the seraphon Player can setup a RSE, GHB is newer so does that mean Player A sets up our engine? ;)
  19. Flo
    Not true, faction terrain has restrictions in the battletome too, for the RSE it is 6" from objectives and 6" from all 4 edges
    So with the GHB it is 6 from objectives, 6 from borders and 1 from other terrain
  20. Killer Angel
    Nope, player A sets the terrains, picked by the players from the listed pieces.
    then the faction terrains are set "in addition to the features that have been set up as previously described"
    (the "previously described" part, refers to the fact that player A places them all)
    so it's the seraphon player that sets up the RSE, but he'll do it after the placement of the terrains by player A. This overrides the old restriction that the RSE must be placed before other terrains
    Canas likes this.
