Contest Golden Serpent 2016
Discussion in 'Painting and Converting' started by The Red Devil, May 31, 2016.
Thread Status:
Not open for further replies.
  1. little-myth
    little-myth Well-Known Member
    Got the model primed, shaded and partially painted so far.
  2. Jorgik
    Jorgik Well-Known Member
    I haven't even started to paint the model yet. I still need to make a nice base for it :D
  3. The Red Devil
    To get the best contrast for the colors, I would suggesting taking the picture with white paper behind the model and with some light shining on the actual model.
    NIGHTBRINGER and tom ndege like this.
  4. Essmir
    Essmir Well-Known Member
    You can do that but it's better to use a black cloth. If you use a wite paper the paper will be lighter than the miniature making it hard to see. cloth will not shine so it will be darker than black papper.
  5. Xlanax_lot
    Xlanax_lot Well-Known Member
    Or build a small lightbox! They are so easy to make and the results are great! I just made one for myself a Couple of days ago. Here is how it looks.
    The results are great!
    Sudaj, Scalenex, Bracnos and 7 others like this.
  6. SlanntaClause
    Is that just paper and a cardboard box?
    Rikard likes this.
  7. Phoedinn
    Phoedinn Well-Known Member
    *Runs to the works to buy tracing paper*
    Xlanax_lot and SlanntaClause like this.
  8. Stefblo
    Stefblo Active Member
    Xlanax_lot do you use only sunlight or some artificial light for pictures?
  9. Crowsfoot
    He gets great results with natural sunlight ;)
    Bowser and Xlanax_lot like this.
  10. Xlanax_lot
    The papers on the side of the box I am not sure how they are called, but are a type of semy-transparent paper used mostly by painting a design students, it is not totaly transparent. however, cooking oiled paper would work just as fine
    Inside the cardbox is just white or bleck paper whichever you preffer
    I mostly use natural light although artificial white light works great
  11. Stefblo
    Thanks ;) I am just finishing conversion entry. Good to know how to take good quality pictures :)
  12. Jorgik
    Yep that´ll be real helpful thanks!
    Scalenex and Xlanax_lot like this.
  13. SlanntaClause
    Made some more things with greenstuff towards my competition conversion entry - it's evolving and changing as I found out my limitations with the medium :p
  14. tom ndege
    My problem at the moment is the limitation of time... :p;)
  15. SlanntaClause
    I'm new to greenstuff so learning as I use it - also thinking what other things I may need to order means I might have limit on time aswell but I think I know what I need so can look into ordering some :) - I was going to save alittle for the painting competition but it seems the converting one might take up more money than expected :p but if I get the model looking nice it'll be worth it :D
  16. Jorgik
    Just go for it and never fear! My stegadon was my first real go at green stuff and you´ve seen how it turned out!!
    tom ndege and Bowser like this.
    My limitation is skill :D I find green stuff unforgiving.
    Scalenex, tom ndege and SlanntaClause like this.
  18. SlanntaClause
    I've only managed to make like 2...1? good thing wit it :p I dare not try any serious work yet other than some gap filling I did
    tom ndege likes this.
  19. tom ndege
    Well... That's a second problem I have... If only the dammed stuff wouldn't like to stick to things it's not supposed to... And if I could learn to leave my fingers away from it and use the tools...;)
    @NIGHTBRINGER: But therefore you are the king of woodworking at this place! ;)
    NIGHTBRINGER and Bowser like this.
  20. SlanntaClause
    I do have a question actually - I think I use too much water when I'm working with it as bits seem to come off in the water and it dries a lime green at times am I using too much?
Thread Status:
