Greenstuff help...
Discussion in 'Painting and Converting' started by Joshua Horchler, Dec 20, 2018.
  1. pendrake
    The pros use incandescent lamps mounted over coffee cans to speed dry what they have sculpted. The can concentrates the heat.
    They also experiment with the mix. (I think a slightly higher percentage of blue[?] will speed along the hardening...but reduce working time.)
    Otherwise. Wait Patiently.
    Other pro tips:
    • lubricate tools with water, frequently.
    • Or, reduce stickiness of tools with Petroleum Jelly; but be wary of getting a lot of PJ in the mix between layers. It retards drying and can even de-laminate the sculpt (if it’s going to be cast).
  2. pendrake
    Plastic Bird spikes are inexpensive. (It’s a product meant to foil roosting pigeons and other nuisance birds.)
    Trim them to length desired; attach with blob of greenstuff at the base.
