GW News: LAS VEGAS OPEN 2025
  1. Imrahil
    I will most likely not take this box, for the same reason as @Killer Angel . Not much added value in the box than buying all the models separate.
    For the Vanguard box I suspect there will be at least one of the new units in there. I am guessing the new Scar-Veteran on Agraddon.
    Just A Skink and Killer Angel like this.
  2. Erta Wanderer
    Cheaper than I thought they'd be
  3. Erta Wanderer
    looks like trade prices, i expect a 20% increase due to looking at the Cerberus heavy tank
    Just A Skink likes this.
  4. PlasmaDavid
    PlasmaDavid Active Member
    Even though I already have waaay too many Saurus and two metal Slann I'm totally on board with those minis if they release as a normal discounted box set.
    TOW confirmed at Warhammer Fest...
  6. Killer Angel
    well, that's interesting...
    You'd have to imagine that it's release is somewhat around the corner.
  8. Killer Angel
    Sure, but there were so many corners that i lost the count... :p
  9. Lord-Marcus
    I don't like the skink cavalry enough to paint 10 of them, so no preorder for me.
  10. Lord-Marcus
    I'm more interested in concrete "This is what bases are moving to X size" so i can actually work on projects.
    I'm also of the opinion that they are re-doing the dated TK plastics and keeping the relatively new stuff (TG, necro knights, sphinx.)
    All of which makes me excited, except for the fact that all of the re-released kits are sure to be at New-GW price points, which makes little sense.
    That's true, but this seems much bigger than all the previous announcements we've seen. We won't know until Warhammer Fest, but its very inclusion leads me to speculate that we will see TOW released inside of this year.
    Personally, I have no intention to abandon 8th edition basing sizes. It's easy to upscale a base size (via movement trays, sticking the base on a larger secondary base) but downsizing is problematic. Plus, there is no guarantee that TOW will be any good.
    You're probably right on both accounts.
  12. Lord-Marcus
    i'm doing deuling Dawi, but i can't base anything until i have the appropriate base sizes.
    Dueling Dawi? Vanilla Dwarf vs. Chaos Dwarf?
    I guess you're fully on board with TOW then?
  14. Lord-Marcus
    Correct on point 1.
    Eh, on point two. I have projects planned and I'm q beginning state, this would just give me two to play with and learn the rules
  15. Cristhian MLR
    I can not believe they'll won't confirm TOW will come out later this year.
    Maybe they'll have a surprise demo for it? I mean there might be some space in here, somewhere:
    I sure hope TK are one of the early armies. Those Necrosphynxes are .
  16. Killer Angel
    Yeah, a bigger size could be a win-win.
    You just need movement trays of the appropriate size, so you can play both oldhammer and ToW without needing any rebase.
    The only issues could be for single models (monsters...) and skirmishers, but as said, you can alway lay the old model upon a new, larger base.
    Definitely a solvable problem.
    Personally I have no intention of playing both though. Either I stick with 8th or move onto ToW (if it somehow manages to dethrone 8th).
    Most monsters fit pretty well on their bases, so they might not touch those. 8th edition was a bit of a mess in that regard, with monsters having multiple legal sizes depending on if they were the new or old sculpt (Treeman, Carno, etc.)
    I use movement trays for skirmishers too, so that isn't a problem. Unless they change how the skirmishers rule works.
    Killer Angel likes this.
  18. Erta Wanderer
  19. Just A Skink
    First, I'm not sure what Tepok, the Old One more related to magic, has to do with Raptadons? Second, those "Tepok Lances" really look more like clubs, but that's just me.
    Interesting... GW is encouraging us to use the two Raptadon units in tandem.
    Chargers have 3 Attacks at 3+/3+/-1/1 if a Hunters unit targeted (not hit or damaged) the opposing unit.
    Hunters have -2 Rend on a "Starstone Atlalt?" Does this rule mean that a unit of Hunters can shoot twice (once in shooting phase and once at end of charge phase) provided the conditions are met?
  20. Erta Wanderer
    it does! 4/4 isn't wonderful but it's 20 attacks at rend 2 on a fast unit.
    Tepok is the god of magic but he is also the god of guile and being clever soooo. clever girls
