GW News: LAS VEGAS OPEN 2025
    There are definitely downsides, but just like the horde rule in 8th edition, they might be acceptable sacrifices for all the additional attacks gained. Ten model wide horde units in 8th seemed to be pretty popular. During the course of compiling and running the Best CC units in all of Warhammer tourney, it became undeniably evident just how potent a wide frontage can be.
    As for easier to shoot, that really depends. A very wide but shallow unit is less effected by penetrating fire (cannons, bolt throws) and even templates like a breath weapon (unless you can catch them on the flank).
    Agreed. We'll know pretty soon after its release.
  2. Canas
    Right, I kind of assumed 3 wounds wasn't particularly impressive given that the other spell already does 2D3 at higher strength and with -2 AP, and it still only has a 7+ to cast.
    Low wound count though in fantasy then.
    That doesn't really change any of the potential issues a mechanic like this brings.
    Anyways, who knows, maybe they'll manage to avoid the issues when putting it into practise, though knowing GW I'm sceptical of that :p.
    You get a bonus for number of ranks to you combat score thing, so there's that as well.
  3. Lord-Marcus
    I'm really liking the new heroic deeds rule for FEC previewed today.
    The throwaway line at the top of the article that all Kings have sworn banner to ushoran tells me that he's back under the control of the gash at least partially and is trying to bring all of the flesh eater courts to bear as a horde against the living
  4. Krox_v.2
    Krox_v.2 Well-Known Member
    The Overkill challenge mechanic has been a part of Warhammer Fantasy since 5th edition at least. Given how long it was around, I doubt it generated that many balance issues.
  6. Canas
    Sigh, why can't we have some undead that aren't aligned with Nagash. It's so boring.
    It isn't the overkill mechanic specificly.
    Also, it won't necesarly lead to balance issues in the sense of overpowered units or something. Just in weird scenarios where you pull of a great manouvre like a rear charge, and end up losing combat anyway because that meagre +2 immeadiatly was cancelled out by the opponents banner and extra ranks or something.
    Doesn't seem too terrible.
    Considering that they are based on 30mm squares and WHFB Saurus are normally based on 25mm squares, it's far from ideal. Even on the 30mm bases those tails are problematic. Cool models, but I can't see them working out for my army.
  8. Canas
    I mean, the new models are a tad bigger. Expecting them to be on 25mm is a bit optimistic.
    Important distinction: I was expecting them not to rank up on 25mm bases, but I was hoping that they would.
  10. Canas
    Fair enough, still optimisitc though :p
    Anyways, my point is more that they seem fine for old world stuff as I assume they take this into account for their new (old?) lizardmen rules and put them on new bases and what not.
    Also, didn't they mention somewhere that you could play with round bases or something to make it so models could be used in both games without needing to constantly rebase them?
    Hoping for something but knowing that it will not come to pass is the opposite of being optimistic.
    Maybe. Since I don't play AoS, and I have no intention to play TOW, it makes little difference to me.
  12. Krox_v.2
    Only thing I saw was that the TOW rules have been written that in friendly games, retaining the old square base sizes didn't matter so much, whereas for tournaments and such, it would probably be best to rebase them. Nothing regarding round bases, though I'm sure one could find or make movement trays to accommodate round bases.
    Pretty much the same thing was said when AoS first dropped. Eventually the old base sizes will be phased out. Players can always choose to agree to allow old base sizes, but I think it will be increasingly frowned upon as the game matures.
  14. Canas
    I thought they mentioned something about movement trays and some other accommodations for round bases. Explicitly mentioning that you didn't need 2 collections to play say AoS Seraphon and ToW lizardman, at least where compatible models are concerned (e.g. named characters might not carry over, but saurus warriors should)
  15. Lord-Marcus
    FEC army box will be up for pre-order within a week to two.
  16. Krox_v.2
    https://www.warhammer-community.com...t-diary-on-bases-and-the-barons-of-bretonnia/ I'm going off what's in this article. It doesn't mention anything about AOS and round bases, though I have heard rumors myself of a similar sort, though seeing that picture of the new saurus warriors on 30 mm squares has me doubting them now.
  17. Krox_v.2
    It seems that they might be somewhat accommodating of those players who don't want to rebase their armies, based on the following quotes from that article:
    1. Do I need to rebase my old army?
    2. If you’re playing at home there’ll be no requirement to rebase anything. For casual play, the size of base will make a minimal difference to gameplay. The rules will be written assuming the new larger base sizes – so if you’re planning to play competitively, you might want to upgrade to larger bases,
    If you don’t want to rebase your older models individually, you are welcome to pop them onto a movement tray with the right footprint. In practice, movement trays are a useful tool, even if your army is on the right base size, as it speeds up gameplay and makes for more accurate unit manoeuvring.
    Q: Can I take my old armies to organized play events?
    A: Sure! But organized play events (tournaments, campaign events, etc) will probably require armies to be based appropriately for the new game (or on an appropriate movement tray). Organized play requires some standardization and this is the best way to do it.
    Home games are a very different story. GW has very little power there.
    The real question is how will the majority of games played at GW stores or FLGS be handled? At the onset, I suspect no one will have an issue with old basing standards. As time goes on (assuming the game survives), things will likely shift towards the new official sizes.
    If someone doesn't want to rebase, I think specialized movement trays will be the way to go or...
  19. Lord Agragax of Lunaxoatl
    For any fellow War of the Worlds fans out there, GW are now going to make Red Weed for basing. Yes, really.
    Just A Skink likes this.
  20. Killer Angel
    That calls for Necrons' tripods! :)
