AoS Help Vs Nighthaunt
Discussion in 'Seraphon Tactics' started by Mokomoko, Apr 22, 2019.
  1. Mokomoko
    Mokomoko Active Member
    What’s the std book?
  2. Erta Wanderer
    slaves to darkness it has a lot of counter play to our main strats it's heavenly anti ranged and makes it impossible to make a 9" charge
  3. Mokomoko
    In that case, it’s good he doesn’t play them.
  4. Lizerd
    Lizerd Well-Known Member
    What stuff did STD recently get? I’m interested
    @Mokomoko I was going to suggest spamming razordons but I see @Killer Angel @LizardWizard and @Canas already suggested it!
    One key thing to keep in mind is that nighthaunt have somewhat brittle battleline, with decent saves but most of them are limited to a single wound which limits the amount of damage they can take
  5. Killer Angel
    Yes, but those battlelines can be ressed and it's not easy to wipe a chainrasp horde.
    Plus, i expect to see an increase in fast & heavy hitters as the Black coach, given its points decrease.
  6. Erta Wanderer
    khorn deamon princes can make terane block line of sight and halve the charge rolls withing 18" of them this makes shooting hard as you cant teleport shooting and the saport in the same turn and no one in the game can make a 8" charge. mix the with a ability that your hit rolls of 6 hurt you and a few spells that make it so that you can't move STD is a very trolly army
  7. Mokomoko
    Well, he’s asking for the Chainrasp horde for Christmas, so... guess I’d better watch out. I’m asking for one razordon with 3 skink handlers. Fortunately he doesn’t have the Black Coach.
    Lizerd, LizardWizard and Killer Angel like this.
  8. Mokomoko
    Again, so glad that he doesn’t use Slaves to Darkness
  9. Canas
    can't some destruction armies still make the charges with relative ease due to their obscene amount of modifiers?
  10. Erta Wanderer
    iron jaws ard boies can do it if they are being buffed with cogs 12 on the dice +3 natural +2 cogs is 17 rounded down to 8"
  11. Canas
    mm, thought there were once that managed more.
    Lizerd and Erta Wanderer like this.
  12. Erta Wanderer
    well the war chanta has a 4+ prayer that lets them roll 3d6 for the charge but that still gives them a 40% chance to fail a 6" charge sooooo ya no one gets to charge STD
  13. Lizerd
    Instead we will just shoot them to the ground?
    Erta Wanderer likes this.
  14. Erta Wanderer
    nope because if they are marked nurgle then it's -1 to hit them with shooting and despoilers can make any terrain piece into a wyldwood so shooting doesn't work either
  15. Canas
    in fairness, they can\t really do all of that at the same time (are mixed mark armies a thing? please tell me mixed marks get punished... o god GW totally missed the obvious problem that's mixing marks freely is bound to be didnt they?). So you'l be able to use at least one of the approaches.
  16. Erta Wanderer
    actualy no you can have mix marks in your army but only nurgle heros can buff nergle troops and so on. but you can run a dispoilers army with a prince of khorn and a few heroes of nergle buffing troops of nergle and even better if you use the
    Plaguetouched Warband (Nurgle Warband. 180pts, Min 900pts, Max -pts)
    1 Mortal STD Nurgle Hero, 7 Mortal STD Nurgle units.
    Unmodified wound rolls of 6 on attacks targeting units from this btn result in the attacker taking 1 mortal wound. Also, in your hero phase, pick an enemy target within 1" of any unit in the battalion. On a 3+, that enemy unit takes D3 MW.
    then not only can you not charge or shoot them but after they charge you you take damage from hiting or shooting them so have fun with that it also makes your army a 2-3 drop
    not insurmountable but it's a very trooly army
  17. Canas
    isn't the plaguetouched warband's effect melee only? Thought they idea was they just bleed on top of you and infect you.
    And meh, I think it's probably not going to be too terrible. But yeah it's quite trolly. The biggest issue I guess is trying to predict which variant you'l face as they need wildly different counters.
  18. Erta Wanderer
    it should be but isn't
    well i beleave you can make it a d3 mortals but ya the mane reason you take it is to put you're intire army in it so that you're a low drop army
  19. Canas
    o for crying out loud... you'd think they'd learn to be more carefull with their phrasing... I guess it balances out against their general lack of ranged firepower a bit. But damn that ruins armies like the KO who are squishy and rely on shooting the enemy without being touched themselves.
    On the bright side, it does mean Kroak is the supreme counter against StD which is rather fitting. Spells that do not care about line of sight and LoSaT to get into position. Kroak cares not for the puny powers of chaos.
    Mokomoko and Erta Wanderer like this.
  20. Mokomoko
    What’s the KO army?
