AoS How would you feel if you had to re-base your Lizardmen army for 9th edition?
Discussion in 'Seraphon Discussion' started by NIGHTBRINGER, May 18, 2015.
  1. Excited!... round bases look better than squares!
    9 vote(s)
    9.5%
  2. Indifferent... don't care either way
    7 vote(s)
    7.4%
  3. Frustrated... it will be a huge chore, but I'll what it takes to be compliant in 9th
    12 vote(s)
    12.6%
  4. "Oh no they didn't"... I refuse to rebase! (make due with squares... or forget 9th)
    67 vote(s)
    70.5%
  1. pendrake
    @borkbork :: That invites this question: where did the round+square pix come from / who shot them?
    borkbork likes this.
  2. borkbork
    borkbork Active Member
    yeah, good question. They looked legit to me, but the hexagon one also looks quite convincing, and we know that is a fake. You got to hate (or love) the internetz and photoshop though! We have the means to fake everything and there will always be one willing to do so.
    Very true. We can never be fully certain. Best we can do is accumulate evidence from multiple sources in order to weed out the fakes from the true rumours.
  4. Lord Grok Of Xillaqua
    Lord Grok Of Xillaqua Well-Known Member
    A task much like scrying the winds of magic themselves, come to think of it. :eek:
    The question is, will 9th edition be our miscast?
  6. Lord Grok Of Xillaqua
    If it does, will it go off like this?
    Or like this...
  8. Herr Pete
    Herr Pete Active Member
    Fantasy and round bases just isn't cricket. My army is still under construction and there is no chance I'm switching to round bases. Unless they brought out round bases with a square in the middle for your current model to sit in. However I can imagine this would take up a lot of space on the table.
  9. pendrake
    :D
    ReaperMinis wrote a very excellent skirmish game called Warlord. It used square-cornered bases for everything. And it has a faction called Reptus (Lizardmen). (And it is a carefully balanced game...balanced games ARE possible).
    Warhammer tables used to be 8 foot x 4 foot. I have the evidence. In hard copy. Warhammer Siege used 4x8s for every setup diagram.
    Herr Pete likes this.
  10. Lord Grok Of Xillaqua
    How big did siege games have to be to need that much table space?
    But if Warhammer went back to 8'x4' tables, room space might become an issue. In most gaming stores, space is an issue. If the tables are bigger you have to reduce the number of tables available. The other issue is that most stores/people may already have standard 4x6 tables, so building new larger ones is problematic... especially if other game systems run perfectly on the standard sized tables.
  12. borkbork
    I have an 8x4 table (125x250 cm) and it indeed is f-word huge. It does not look too big in this picture but trust me, it largely fills the room. And that is a pretty decent sized room.
  13. pendrake
    I guess the space issue(s) might be why they switched from 4x8 to 4x6 at some point. Siege games needed to accommodate the standard Warhammer Fortress model along one of the long edges and then provide space for the OpFor to approach from three directions... ...maybe that is the reason for the extra table space.
    That's an epic table. I bet you could play a colossal game on that.
  15. Rikard
    Rikard Well-Known Member
    I refuse to re-base!
    The amount of effort it would take is not something I am willing to put in, it won't stop people playing against me though either.
  16. pendrake
    @Rikard has anybody measured these new bigger round bases accurately? I was drawing squares and circles and measuring things. Results were interesting. The ratios are interesting:
    20mm Square / 25mm Circle
    25mm Square / 32mm Circle​
    The ratio is reeeaally close. (See my next post)
    With the current rumours the way they are, it doesn't look like rebasing will be necessary. Apparently anything goes.
  18. pendrake
    Here is Siggyknight again. With Bases.
    The bottom square and circle are 25 & 32mm.
    The upper pair are 20 & 25mm.
    Notice how the squares stick out by almost exactly the same amount compared to their respective circles...
    Slanputin likes this.
  19. Crowsfoot
  20. Lord Grok Of Xillaqua
    Yep, it's official. Bases don't matter for anything more than decoration in AoS. I'm square with that :cigar:
    NIGHTBRINGER, pendrake and n810 like this.
