8th Ed. I apparently have no clue how to play, can I get some help?
Discussion in 'Lizardmen Discussion' started by Pinktaco, Sep 19, 2013.
  1. RipperDerek
    RipperDerek Active Member
    Re: I apparently have no clue how to play, can I get some he
    Yes, basically. There are also other options for flankers if you don't like the krox (cold one riders, another ancient steg, etc.). But the krox seem good against all his 1+ armor saves, and a unit of them in the flank will almost kill his entire knight unit outright. Just be careful they don't get charged or shot up by cannons too badly before they get the opportunity.
    To answer your other question, yes, you get the lore attributes. And you don't need Lore of Metal, just Searing Doom is probably good enough. An IF Searing Doom will cripple his Steam Tank into uselessness on an average roll, with only a moderate chance of making your Slann go ka-boom.
  2. Padre
    Padre Well-Known Member
    The biggest difference between what you run and what I normally run is that I mostly play at 2500 . My list is probably not the most competitive list, but is based on what I have right now and what I can proxy. And, honestly, I have no idea how I'd do against what you're dealing with. I'd have to look and see what I'd drop to get myself down to 2000.
    I'll post a fuller version of my 2500 pt. list in the Army list forum later, but here is the core:
    WD Slann
    2 Priests
    Cowboy Scar Vet
    2x 25 Warriors
    2x 10 Skirmishers
    21 TG
    9 Chameleon Skinks
    SolarDon
    Ancient Steg
    At 2k, I'd probably drop the Bastilladon, the Scar Vet and one of the Priests and find a couple other points to drop, maybe running a Light Slann instead of WD. I'll have to point it out and see.
    Padre
    Edit:
    Here is a link to my current list.
    http://www.lustria-online.com/threads/2500-tournament-list.13030/
    At 2000, I think I would drop the Bastilladon, the Scar Vet, the priest with the cube, and a couple magic items. Also, I'm not completely sold on everything in the list. Both the cube priest and the scar vet are negotiable, but this is what I'm running as of right now, mostly because that is what I have or can easily proxy.
  3. VampTeddy
    VampTeddy Active Member
    Yes, you get the associated lore attribute og whatever you cast.
    Wyssan's gives Beast's attribute.
    Searing doom Metal's, and so on ^^
  4. DeRailed_612
    DeRailed_612 New Member
    What is the FLGS?
  5. n810
    Friendly
    Local
    Game
    Store
