I f***ed up! Pls help
Discussion in 'Painting and Converting' started by milman, Dec 19, 2016.
  1. milman
    milman Active Member
    Oh damnit why!
    I tried out some colour pattern on my starpriest and it sucks! How do i best fix it? Do just give him another layer of a different colour or is it possible to get the wrong colours back of my model? (Used the new plastic model)
    Just affraid that i might cover up the details if i would give it another layer or 2 to cover it up ...
  2. Acrocanth
    Acrocanth Well-Known Member
    Painting over is the simplest solution but does have the possibility of losing details. If you're working in thin layers it probably won't be too big an issue but the finer details will be at risk.
    Option 2, I havn't tried it but simple green is what I've heard most people using to try to strip plastic. Here's a link to a procedure http://www.dakkadakka.com/wiki/en/WarOne's_Simple_Green_Stripping_Method
    Best of luck it happens to us all.
    milman, Bowser and tom ndege like this.
  3. tom ndege
    I use a plastic cleaner to strip models... Just a bath of some minutes (or weeks ... As I found a cold one in a box with cleaner that's lying there... Well since August I guess ;)) If the paint is still fresh it should be no greater problem to remove it... The revell colours I used 20 years ago were... ;):p
    milman and Bowser like this.
  4. Crowsfoot
    None acetone nail polish remover does the trick, just test a sample first.
    tom ndege likes this.
    That's what I use on my metal models.
    n810 and Crowsfoot like this.
  6. Jorgik
    Jorgik Well-Known Member
    I just use oxygenated water or wound-deinfecting alcohol. Though donĀ“t leave it overnight or it might melt a bit to the plastic. I just leave them for about an hour and then scratch the paint off with an old toothbrush. Hope it helps ;)
  7. Iblitz
    Iblitz Well-Known Member
    I use one night of liquid break bath for plastic models.
  8. Lawot
    Lawot Active Member
    Started using Simple Green on the recommendation of people here. Only used it on metal models so far, but it hasn't melted their plastic bases, so that's a good start!
  9. n810
    :snaphappy: I think we need a picture... :photogenic:
    milman and Jorgik like this.
  10. milman
    Its all solved! Thanks for the tips guys
    Excellent... good to hear! :)
