TOW Lizardmen full unit tierlist
Discussion in 'Lizardmen Discussion' started by airjamy, Mar 20, 2024.
  1. discomute
    discomute Well-Known Member
    Unless anything changed in the FAQ, taking an additional hand weapon means you don't get poison on either.
  2. airjamy
    airjamy Well-Known Member
    It kinda depends on if you think your Steg will be charging. If he will be charging, cav spear, if you do not think so, additional handwpn.
    If you are charging that is. :)
  3. airjamy
    Why? It is not something like Obsidian Blades that stipulates handweapons, if you just have the poisoned attack special rule all your attacks, except magical weapon attacks, gets them.
    Poisoned Attacks
    Deadly toxins can turn an otherwise minor
    injury into a mortal wound.
    If a model with Poisoned Attacks rolls
    a natural 6 when making a roll To Hit,
    that hit will wound automatically. Unless
    otherwise stated, a model with this special
    rule may use it when making both shooting
    and combat attacks. Any spells cast by the
    model are unaffected, as are any attacks
    made with magic weapons.
  4. discomute
    Interesting, well I guess you're right then and yes an extra poison attack for a few points is a bargain
  5. Kalisto
    Kalisto Active Member
    You can still use the shield ward save if you avoid to use the Stegadon armour save
  6. PlasmaDavid
    PlasmaDavid Active Member
    Shield ward save? Like a magic item as a backup if your armour gets completely negated?
    Kalisto likes this.
  7. BeardedLizard
    BeardedLizard Member
    About the new post-FAQ Slann:
    If you want to stay in dispel range of enemy casters then you're most likely in range of their spells. A couple of fireballs and you have yourself a dead frog and ethreal is not going to help. Ethreal still important vs normal shooting though.
    If you don't use Slann for dispelling then a huge part of his strength is missing.
    I feel the real new tax for Slann might be both a unit of Temple Guard and the ethreal upgrade.
    discomute likes this.
  8. Kalisto
    Becalming cogitation my help too. But yes temple guard is much more important now, especially for a non ethereal Slann.
