AoS Made to order seraphon GW
Discussion in 'Seraphon Discussion' started by Jatipower, Sep 3, 2018.
  1. Aginor
    Well, finecast is a kind of resin. There are others but AFAIK the only one GW uses is the one they call finecast.
  2. Tokek
    Tokek Well-Known Member
    From the last made to order things I bought I would say that anything which has only ever been in metal still seems to be metal when they do made to order.
  3. Crowsfoot
    Correct, they use the same moulds as original so the models are always what they were first produced in, if a model has been produced in more than one material they will usually use the latest mould.
  4. Aginor
    Ok, so those might actually be metal?
    Hmmm interesting for me then, as I have never painted a metal model so I'd like to try that.
  5. nomis
    nomis Well-Known Member
    Any idea on the cost of these yet?
  6. Canas
  7. Deed525
    Deed525 Well-Known Member
    Hmmm both have draw backs lol,
    Metal - you touch or move the model and bam it’s scratched and you see shiny metal under all your hard work.
    But resin...4 hours of shaving down the mould
    Lines only to find every sticky-out-bit is wonky and can never be strained again :D
  8. Canas
    mwha, metal with varnish isn't too awefull. Especially on smaller models like this. It's not like it's a giant dinosaur that's inevitably going to be bumped into things.
  9. Canas
    They've been released Tehenhauin is 20, oxyotl is 12 euro. It doesn't state what they're made out of though.
  10. Aginor
    Probably going to order the Prophet. Nice model.
  11. ILKAIN
    ILKAIN Well-Known Member
    I cant see them... are they regionally locked? Im in the US.
  12. Aginor
    Strange. Yeah if I pick US in the country menu I can't see them either.
    German site has them.
  13. Cerind
    Cerind Member
    Oxy is resin, the other one isn't specified.
    There seems to be a consensus that while fine cast and "resin" are both resins, fine cast was a blend that gave very brittle and unpopular models, while the more modern "resin" is better. I just got a Kaptin Baddruk and it's quite nice in quality and sturdiness.
    I'm OK with metal, being a Sisters of Battle player, just have to use varnish and a playing mat rather than solid board to avoid accidental diving into oblivion :)
  14. Crowsfoot
    So glad I didn’t bow to temptation and get Oxy of ebay, £10 is a bargain
    pendrake likes this.
  15. pendrake
    I am pretty sure I will order Oxy and perhaps the Bretonnian King.
  16. nomis
    So, can I ask a possible total noob question.
    Is it possible to use these models with a seraphon army in AoS? If so, where would I get the point value of these models?
  17. Crowsfoot
    They won’t have match play points, I’m going to use Oxy as a chamo skink so he just falls in with the unit price, Tech you could use as a Skink priest
  18. Cerind
    Cerind Member
    They have rules, but no point values, as they are meant to be used in narrative /open play. I'm sure some tentative, player-proposed point values will pop up online in due course to accommodate them in friendly matched play games :)
  19. Juxtion
    Juxtion Active Member
    Proud owner of both in 1-2 months lol
    ILKAIN likes this.
  20. ILKAIN
    ditto
    Juxtion likes this.
