I'm trying to make a table for my anyday gaming. Of course i want it to look at jungle as it can be. I started off by cutting down a piece of already sanded down plywood to 4X5. I just covered it with a coat of a dirtish brown color and now i want some type of jungle ground effect to it.. But i don't know how to make the effects happen. For example if you look on the back of your lizardmen books (new ones) and you'll see the ground how it has the grassy/dirt look and it is popping up like bubbles. On page 77, you'll see on the bottom right corner in front of the saurus with spears, the grass is grass and where can you get mass amounts of it besides buying the GW tiny tubs of it.. Want this table to look mint, give me some advice, pictures would be awesome too.
You might want to check out this site for grass and ground cover... http://woodlandscenics.woodlandscenics.com/index.cfm also check out some plastic plants in local derpatment stores, craft stores, and pet stores.
Well I took on the same project as well and this site here has an amazing and affordable selection of jungle plants that I used. http://www.aquariumguys.com/jungle-florals.html
