8th Ed. More Newbie Questions
Discussion in 'Rules Help' started by TommyM, Feb 1, 2015.
  1. TommyM
    TommyM New Member
    How does this Little Waaagh hex spell effect Predatory Fighter special rule?
    Gork'll Fix it - Target unit must re-roll any of its To Hit, To Wound and armour save rolls of 6.
    Can a magic missile be fired at a unit in a building?
    If I have a Skink Priest in a building (Dreadstone Blight in this case), to determine spell range do I measure from the priest's base or the edge of the building?
    Thanks
  2. Trociu
    Trociu Active Member
    Whenever you are rerolling the previous score is something that never happened so you gain extra attacks if 6 is followed by 6.
    2.
    Yes, units in buildings only gain hard cover and since you don't test BS when casting... Let's say that fireballs are fun to cast into buildings.
    3.
    Units in buildings are not standing in any particular place of the building so you are using edge of the building when shooting or casting spells.
    But I wonder how you determine floor for checking LoS of the caster?
  3. TommyM
    TommyM New Member
    Thanks for that.
    Maybe it could be assumed the model is able to run up and down the stairs in a building as needed for LoS.
