Scalenex
Keeper of the Indexes
Revising and extending...
Adding to the myth ^ Common Silver can be the remains of ancient Silver Dragons. If one ever died (and they did finally age out) they collapsed into a heap of silver scales, which degenerated to common silver. These hoards were the inspiration of all coinage. (When alive their scales are not triangular like most Dragons but instead they are round.) Coin hoards are Nature-magic!
SovereignSilver is imbued. It has the combined properties of Titanium and Platinum as well as other magical qualities as needed. Left too long though it can devolve, usually does devolve into Common Silver.
If anything, sovereign silver should be the remains of Silver Dragons and regular silver be all the other silver.
EDIT: I really like the name of "Sovereign Silver"
This Dragon Idea is worthy of abandoning. I recommend jettison immediately.
Noted
Coal
Just let coal exist. Make it a ubiquitous rock. Don’t explain with a legend.
Agreed.
Gems
In that Age of Dragons you had, there were herd beasts. These existed in a variety of colors (much like D&D chromatic and metallic dragons) and they were Scaly creatures. They covered the landscape. They grazed on rock and dragons in turn grazed on them. Whatever these (now extinct) critters were they turned raw rock into earth and clay by digesting/excreting it. But their output was, at times, laced with hardened crystals. E.g., gemstones. The color of the stone corresponded to the color of the beastie. Red beastie = rubies, and so forth.
So you don't like the idea of dragon poop being fuel but you are okay with dragon's food's poop being treasure?
I respectfully disagree.
Miniature figures are made of Tin!![]()
Also without Tin there is no
bronze. No bronze. No Bronze Age.
And Copper. But you’ve been passing out copper pieces already [?] so that’s sorted.
(Bronze = 9 parts Copper + 1 part Tin)
I don't give a tinker's cuss about tin! (Tinker's refer to metalsmiths who focus on tin and similar metals, I don't know why their cusses are used as a form of measurement)
I don't see why Scarterra wouldn't have bronze. I just think that once you have the capacity to work iron, even wrough iron, bronze is pretty much outmoded.
Bronze is good for decorative items, but in terms of weapons, armor, and tools, iron is better in most cases.
The dragons and/or elves might have had a Bronze Age but I think humanity would probably skip the bronze age because dwarves predate the first humans and they could share iron working secrets. Maybe the southern continents which are largely dwarf free would have a bronze age of sorts, but they would probably assimilate ironworking from northern humans relatively quickly. The southern continents used to be elf dominated for a short time so if the Third Age elves had iron working, the southern humans would pick it up from them.
