AoS My new 2000pts
Discussion in 'Seraphon Army Lists' started by sawalak, Mar 24, 2020.
  1. sawalak
    sawalak Well-Known Member
    LEADERS
    Skink Starseer (140) - General -
    Command Trait : Strategic Genius - Artefact : Talisman of Blinding Light
    Saurus Astrolith Bearer (140)
    Saurus Scar-Veteran on Carnosaur (210) - Greatblade - Artefact : Relic Blade
    Saurus Sunblood (130)
    UNITS
    40 x Saurus Warriors (320) - Spears
    10 x Saurus Warriors (90) - Clubs
    12 x Salamander Hunting Pack (240)
    BEHEMOTHS
    Bastiladon (220) - Weapon : Solar Engine
    Bastiladon (220) - Weapon : Ark of Sotek
    BATTALIONS Sunclaw Temple-host (140)
    COMMAND POINTS Extra Command Point (50)
    TOTAL: 1990/2000
    EXTRA COMMAND POINTS: 2
    WOUNDS: 128 LEADERS: 4/6
    BATTLELINES: 3 (3+) BEHEMOTHS: 3/4
    ARTILLERY: 1/4
    ARTEFACTS: 2/2
  2. ILKAIN
    ILKAIN Well-Known Member
    interesting build. may I ask why the greatblade instead of the spear on the SCARNO?
    also... you are intentionally building the club warriors under 15 models required for the extra attack. is there a specific thought process behind that?
    the salamanders aren't artillery any more. just a book keeping thing.
    Lizerd likes this.
  3. Lizerd
    Lizerd Well-Known Member
    Looks interesting, could be pretty good with a few changes. First off it would make sense to divide up the unit of 40 so that each unit of saurus warriors have 20 models, for the extra attack and the rend of cubs.
    Ither things I’m curious about; bastiladon’s are cool, but I don’t feel they are optimal in a saurus based list unless your running thunderlizard. The points would probably better spent on salamanders imho
    sawalak likes this.
  4. sawalak
    yes., thank very much
    Lizerd likes this.
  5. sawalak
    Any friends can make the list to defeat 3 mortek crawler list?
  6. sawalak
    LEADERS
    - General
    - Command Trait : Strategic Genius
    Skink Priest (70)
    - War Spear
    - Artefact : Obstinate Blade
    UNITS
    - Spears
    20 x Saurus Warriors (180)
    - Spears
    - Clubs
    12 x Razordon Hunting Pack (240)
    20 x Skinks (120)
    - Boltspitters & Moonstone Clubs
    BATTALIONS
    ENDLESS SPELLS / TERRAIN / COMMAND POINTS
    Quicksilver Swords (30)
    TOTAL: 2000/2000
    EXTRA COMMAND POINTS: 1
    WOUNDS: 164
    LEADERS: 4/6
    BATTLELINES: 4
    BEHEMOTHS: 1/4
    ARTILLERY: 0/4
    ARTEFACTS: 2/2
    ALLIES: 0/400
  7. sawalak
    Is this working?
  8. Alladin the Paladin
    A few comments:
    1) I think overall the unit mix is quite good. They all augment each other fairly well.
    2) Is there a reason you are using these two artefacts and NOT running koatls claw? Frankly, I think you are doing yourself a disservice by not slapping the command trait on your Carnasaur or Sunblood. The artefact as well is pretty good, and for the second artefact you could go Aetherquartz or Eviscerating blade for more killy-ness.
    3) I don’t know how much mileage you will get from the unbound quicksilver swords (unless playing chaos). I think there may be more utility in something like prismatic palisade, to block a charge lane or LOS from sniping your Starseer or priest, and at least can’t be used against you
    4) Salamanders do outperform Razordons handedly, especially coalesced with the extra melee bite, so if you are able to play them both as salamanders I recommend. They won’t be this cheap (points-wise) forever is my prediction!
    Otherwise I like it as a saurus list
    Nart likes this.
