My return to painting and converting
Discussion in 'Painting and Converting' started by Krox_v.2, Oct 9, 2022.
  1. Krox_v.2
    Krox_v.2 Well-Known Member
    Been a bit since I've done any painting. Had to get a new computer plus I had some serious burnout to deal with. But I recently finished 3 Chaos ogres of Nurgle. I used a mixture of GW, P3, Army Painter and Vallejo. Skin was base coat Catachan skin/Rakarth fles, 1st layer Rakarth flesh, 2nd layer Rakarth/Ionrach mix, final just Ionrach. Army Painter Dragon Red was mixed with Rakarth to paint the skin where the spikes poke through to make it look inflamed. Rusty weapons/metal were painted with Catachan skin base, Catachan/Army Painter Dry Rust mix stippled over, then Dry Rust then GW Leadbelcher drybushed and edge highlighted. I painted some bits of metal here and there as oxidized bronze which was Retributer armor with watered down Vallejo Verdigris over it. Pants were layered from a P3 Ordic Olive/Abaddon Black mix on up to Ordic as final layer. Boots were Catachan skin with gradually increasing amounts of Army Painter Castle Grey added. I painted Vallejo Vomit around the mouth and over the chest for more Nurgle-y "goodness". I'll try and get better pictures in the next couple days.
  2. Krox_v.2
    Painted up 3 of the chaos ogres of Khorne. Skin: base coat of 50/50 Rakarth/Catachan flesh mix, next Rakarth on it's own, Rakarth/Army painter elf flesh, then rakarth/AP Elf/AP corpse pale and then corpse pale for final highlights. Red pants were AP Crusted sore base, AP Crusted Sore/Dragon Red mix and then Dragon Red. Brass of AP Rough Iron base, wash of AP Dark tone, then AP Green tone, then drybush/highlight of AP Weapon Bronze. Iron was GW Leadbelcher, wash of AP Dark Tone then AP Gun Metal. GW Blood For The Blood God technical for the blood effects. I still need to finish the bases.
    Noxolotl, Warden, Imrahil and 2 others like this.
  3. Krox_v.2
    I went back and added verdigris effects to the brass/bronze on the Khorne ogres to add some contrast. I also finished them all, except for the bases. This one is the most extensively converted one and my favorite out of the unit. I cut and scraped down the neck and back of one of the 6th edition chaos mutation heads, cut and scraped part of the ogre's chest, glued it on with plastic glue and then sculpted green stuff around it to look more warped and mutated.
  4. Krox_v.2
    I recently painted a mini as a gift for my dentist.
  5. Krox_v.2
    Painted a second one as part of that gift. Same time, I just took a bit longer to upload the pics for this one. She was very excited and impressed by the paint job on the minis.
  6. Krox_v.2
    I bought this thinking to use it as a Bruiser in my Ogre Kingdoms army, but I have since come up with a different vision for said army. As such I'm probably going to gift this guy to a friend. I do see where it needs a touch up or 2. I also used it to experiment with coming up with a Burgundy color for the chaos dwarf.
    Warden, Noxolotl, Imrahil and 3 others like this.
  7. Krox_v.2
    3rd edition Chaos dwarf. If I play TOW, I think I'll be starting either Kislev, Cathay(if they're actually a faction) and/or Chaos Dwarfs. This was a test mini for a color scheme.
  8. Warden
    Nice work on the corroded metal effect on his shoulder.
    Nice looking chaos dwarf! I like the red too.
  9. Krox_v.2
    Skaven warlord I painted up for my buddy's Skaven. The plastic this thing is made of is ridiculously fragile. Had to reattach the helmet crest/blade and the back banner 1 or 2 times each. I haphazardly applied a green ink wash on the armor and sword to give the impression that warpstone was used in the alloy or in the oils used on the armor and blade.
  10. Warden
    Good looking Skaven, I like his flag!
  11. Krox_v.2
    My new converted Oldblood. I still need to add static grass but beyond that he's done. I had assembled the model before thinking of an idea to convert it to represent the Fencing Blades. so I had to cut off the left arm around the elbow, pin a spear head trimmed down to resemble a dagger and a pommel from a Cold One Rider weapon to the left hand after some shaving and cutting. Beyond that, it's just a standard Oldblood on foot from the Carnosaur kit with shoulder plates from the Saurus Warrior set added.
  12. Krox_v.2
    I took some pictures of a Sabertusk proxy for my Ogre Kingdoms army plus some pictures of chaos monoliths I made
  13. Krox_v.2
    An AOS saurus warrior I painted up as a gift for a friend at my job.
  14. Krox_v.2
    Some of my zombie pirate kitbashes. I used Ghost Archipelago crew and zombie bits. The proportions are slightly off but I think they will work in a unit, especially if I mix some free company and Fireforge bits in there as well.
    Explodingzeb, Imrahil and JTSleep like this.
  15. JTSleep
    JTSleep Well-Known Member
    Great work. You can always blame unfitting proportions to partial bloating on sea. :)
  16. Krox_v.2
    Still working on the Zombie Pirate project. Added bits from the sea critters kit from Epic Basing. This one is my favorite that I've done. My brother dubbed it the "Crab Rave Zombie".
  17. Krox_v.2
    Animated Hulks for my Zombie Pirate force. I converted some Kosargi Nightguard into undead ogre whalers.
    Imrahil, JTSleep and Explodingzeb like this.
  18. Explodingzeb
    Very cool!
