8th Ed. Net of Amyntok
Discussion in 'Rules Help' started by NIGHTBRINGER, Jun 20, 2015.
    I thought I would get everyone's insights on a couple of questions I have in regards to the Light spell Net of Amyntok...
    1. If the Net of Amyntok is cast on a unit with a wizard in it and that wizard tries to cast a spell but fails the strength test, can the wizard still attempt to cast another spell (with an accompanying strength test)?
    2. If the Net of Amyntok is cast on a unit that breaks from combat but fails the strength test (thus is unable to flee), is the unit automatically destroyed if the opposing unit had elected to pursue?
    Looking forward to your thoughts.
  2. ASSASSIN_NR_1
    2. I would presume that the unit is caught, as they are not allowed to flee and therefore must have "rolled" zero.
    I was thinking they would be destroyed as well... since they stay in place and are charged into by the pursuers. This would really add another layer of usefulness to this spell. I have a feeling that it is a better spell than most people give it credit for, especially against low strength armies like Elves.
    Any ideas on the first question?
  4. ASSASSIN_NR_1
    It is a bit wierd as the spell has no mention of a wiazrd, just a unit, and I am not aware of any unit that is able to cast spells (might be wrong).
    The way I think it works, is that wizard failing the test, will still be able to try his/her other spells. If the wizard could not cast any spells if the test was failed, I would say that the spell should be harder to cast, as it would more or less, like the end times spell for high magic, just with a 50% percent chance of the wizard not being unable to cast, and shutting down the enemy's magic phase, instead of a guaranteed shutdown. Most wizards do not have very impressive strength, making it easy for them to fail.
    In addition the spells says: "every time it" (the unit) "moves", which must mean that it is for every spell, and not only a single time to determine whether or not the wizard can cast.
    There are a few: Pink horrors, Doomfire Warlocks & Sisters of the Thorn. Mind you that only pink horrors were around at the time of the writing of the 8th edition BRB and the Net of Amyntok spell.
    I'd say that is a fair interpretation, one test each and every time the wizard attempts to cast a spell.
    I would also argue that no power dice would be expended because the strength test occurs before the casting roll. Thoughts?
  6. Agrem
    Agrem Active Member
    I'd say the second question is quite clear - the unit is destroyed as it cannot move.
    The first however is not clear as you have mentioned. We play it here with my friends that only one test per phase and if it is failed then you cannot act in that phase. Since the "every time unit moves" can also be a reference to moving in multiple phases. If you would be able to test multiple times for casting a spell or different spells wouldn't you be then able to test multiple times in movement phase until you succeed? Or then once for charging, once for marching, once for normal move, once for reform? Wouldn't make much sense in my mind.
    I believe ETC FAQ (if you believe in such thing :D) has ruled it also being one test per phase.
    I would also say no dice are expended if you have failed the test.
    BR
    Agrem
    One down, one to go!
    Agreed. I can see either your inturpretation or ASSASSIN_NR_1's being valid. I was surprised that there was no FAQ entry for it.
    I wouldn't liken spell casting to movement. A wizard is permitted to cast each of his spells per phase (subject to availability of power dice). A unit is only allowed to make a single type of movement per phase...
    • charge
    • regular move
    • march move
    • reform
    • shift reform
    • fleeing move
    Declaring a charge for instance prevents the unit from attempting any other move. If a unit flees, it can not attempt any other type of movement. A swift reform is a special move that encompasses a reform+movement, but I'd still consider that a single move. So while a caster is permitted to make multiple casting attempts per phase, a unit is only allowed to make a single move per movement phase (though it can flee multiple times in an opponent's phase I believe).
    I'm not saying that you're interpretation of the rule is wrong, I'm not really sure how it should be played. I just wouldn't use it's effects on movement as justification.
    Although not explicit proof, it is definitely useful evidence that supports your interpretation.
    This is a pretty difficult rule to figure out. Hopefully others weigh in on it. Come forth my scaly brothers and let your voices be heard!... @Scalenex @Pinktaco @Phatmotha-phucka @n810 @Slanputin @borkbork @Qupakoco @pendrake @Crowsfoot
  8. Qupakoco
    The text of the rule says "casts spells." That plural part tells me you can cast more than once and therefore have to test more than once. No mention of phases unless there is alert rule that says you can only take one strength test per phase. Like Panic specifically has. Great way to shut down a lone Slann maybe.
    Magic is a little different thanks to the ability to be able to use it multiple times in one phase. I can understand the ETC rule that limits it to once per phase since you could easily ruin an elfy walk in the park. ETC tries to make things nicer than reality, so that should be the tell tale sign.
    Fully reading the text of the rule leads me to believe that the spell and shooting part was an afterthought since later on it states that the unit "remains in place."
  9. Mr Phat
    Mr Phat 9th Age Army Support
    @Qupakoco - It does limit it to once per face, but not as you write it :D
    In fact it locks down the unit for the rest of the phase!
    In the magic phase it functions like this:
    If he fails his first S-test - he cant cast any spells that round.
    If he succeeds - he can cast all he want.
    Thats how we play it, and how we always have played it, so I cant really contribtue further :/
    although, I find it awkward that you can just move on to the next spell in any case.
    I think one could argue that the wording backs up the ETC somewhat also:
    "If the test is failed, the unit is unable to perform the desired action,"
    referring to
    "moving as a charger, fleeing, pursuing, moving compulsorily, etc.) or shoots or casts spells"
    I read it like he is prohibited to cast SPELLS in plural.
    To go complete lawyer up in this B _ _ _ _ I would like to point out "shoots" is also plural, while you are only able to shoot once.
    Qupakoco and Slanputin like this.
  10. Agrem
    Agrem Active Member
    Sorry to split hairs here but couldn't you from this argue that since unit is only allowed to make a single type of movement per phase but when failing the S-test you are not able to perform said type of movement. Did you then perform it or not? :p If not, then it wouldn't prevent you from trying the next one?
    Anyway I don't think there is a simple solution to this one as it can be argued over and over to both ways especially regarding spell casting. The wording of the spell is just plain poor. As mentioned we also play it as once per phase to keep it simple. :)
    BR
    Agrem
  11. n810
    it's possible to move again with certain magic spells.
  12. Mr Phat
    if you pass the test!
    Not sure what to think... good points on both sides. Definitely a potent little spell... what a wording nightmare!
    Qupakoco likes this.
  14. Qupakoco
    I think "shoots" is a poor word choice also. You could say "the unit shoots" and you could say "the character shoots". Who shot more? Is the character shooting once? Is the unit shooting once?
    I remain by my interpretation but will heed to ETC if I ever play it. I do believe that the intent of the spell is to seriously cripple a unit, as every action it takes is now subject to a strength test.
    And hey, if you don't want your wizard to have to hurt the unit when he "casts spells" you can have him leave. Strength test being passed of course, mwahaha!
    n810 and Mr Phat like this.
  15. Mr Phat
    ironically, given the lore and all, net of amyntok is made to CHAIN AND CRUSH THE WEAK!!!! SKULLS FOR THE SKULL THR*COUGH COUGH*......hm hmm.
  16. n810
    works great on frenzied units. ;)
    We can't seem to find a consensus for question #1... I smell the makings of another poll.
  18. ASSASSIN_NR_1
    so..... How is that poll coming along?
    Or was the smell too faint, so it did not make it all the way to the brain to be processed into a poll for "all" of Lustria Online to take part in, to the delight(or so I believe) of the almighty NIGHTBRINGER Master of polls ;)
