AoS Oldblood on Carnosaur Command ability
Discussion in 'Rules Help' started by Casey, Feb 12, 2019.
  1. Casey
    Casey New Member
    I was wondering if there was any changes from what is stated in the book for Ancient Warlord command ability
    It states whenever a saurus hero within 20" attack in combat phase, pick one of its weapons and +2 attack until end of phase.
    I was wondering if it actually goes for all seraphon heros within 20" or just one hero within 20"(my brother a thinks its overpowered nd just wanto get a clearification)
  2. Sedraxis
    Sedraxis New Member
    It is for all heroes within 20", and it is potentially overpowered :p
    Ecozh, Imrahil and Casey like this.
  3. Killer Angel
    Yeah, it works for all heroes... but it's not overpowered, far from it.
    It's a good buff, but there are craziest things in the game ATM.
    Our strongest tools actually are LoSaT and summoning... those are our main keys to victory, while the synergies granted by our heroes are not game breaking.
  4. Hij4cker
    Hij4cker New Member
    And can he use that on his mount? I mean it's forelimbs.
  5. Putzfrau
    Generall the Jaws are where it's at.
  6. Lizerd
    Lizerd Well-Known Member
    Yes, the command ability can be used for the carnosaur. If attacking infantry hordes then go for the jaws, for monsters use it on the claws as the pinned down can become brutal.
    Schwaaah likes this.
  7. Putzfrau
    Mathmatically, isn't it still better to use them on the Jaws?
  8. Lizerd
    It’s pretty dependent. Against infantry then hands down its the jaws. Again, with monsters you have an excellent probability of scoring pinned down with 4 claw attacks. This means that approximately 2 should deal damage. With this you can use a far more accurate bite with an almost guaranteed hit, multiple times.
  9. Blitzkriyg
    Blitzkriyg Well-Known Member
    Jaws is definitely the best. I run kroak so having 6 or 7 cp by turn 3 to blow is great. Charge in the carno with a sunblood with his exploding 6s backed up by an Astro and its fun times had by all (your opponent excluded)
  10. Vexcor
    Vexcor Well-Known Member
    the ability says: pick one of the heros weapons.
    is it really legal to give the claws or jaws +2 attacks?
    is there no difference between the hero and its mount?
  11. Crowsfoot
    If an ability can't be used on the mount it usually says does not effect the mount.
  12. Blitzkriyg
    Command traits are not conferred to the generals mount, however command abilities are fine unless the ability says otherwise
  13. Imrahil
    Good to know!
    I just want to know if I'm correct:
    If this effects my Scar-Veteran on Cold One, I can choose the Celestial War-pick witch gives me 5 attacks. When I roll a 4 after the attacks i get another 5 attacks because it states: "...until the end of the phase." And after that when I roll a 6 again?
    Gr, Imrahil
    Lizerd likes this.
  14. Killer Angel
    Yes. :)
  15. Aginor
    Yep. :)
  16. MackiMac
    MackiMac Well-Known Member
    Does it stack?
  17. Canas
    yup, the command ability stacks.
    MackiMac likes this.
