Second Spawning
Touche! You got me there!Unless you eat them, of course.![]()
Why not Troglodons?In the battle between two furry, carnivorous quadrupeds, My money will always be on the scaly, carnivorous quadruped. I vote for the Komodo Dragon with the pink collar called "Fluffy".
...because they don't actually exist.Why not Troglodons?
Everything exists. If not, than you wouldn't be here. Besides, look in the gallery for proof of Troglodons existing....because they don't actually exist.![]()
I should clarify... it doesn't currently exist in non-plastic form.Everything exists. If not, than you wouldn't be here. Besides, look in the gallery for proof of Troglodons existing.
Until somebody makes a greenstuff model of it. There is art of Troglodons, and if you view a Troglodon image on an electronic device you are looking at the digital form of a Troglodon.I should clarify... it doesn't currently exist in non-plastic form.
None of those things are going to take out a Komodo Dragon.Until somebody makes a greenstuff model of it. There is art of Troglodons, and if you view a Troglodon image on an electronic device you are looking at the digital form of a Troglodon.
Because the universe is infinite, there might be some other planet that happens to have Troglodons. Also, there's an infinite amount of universes in the multiverse, each one different from each other. Troglodons might be found in one of those universes.None of those things are going to take out a Komodo Dragon.
You need to do better than a Troglodon as an inanimate object.
You're really stretching there. The universe may be infinite, but scientists don't really know and there are different ideas/theories. If the universe was infinite, then not only would you find something like a Troglodon but there would be infinite numbers of them. Infinity is a strange beast. There would actually exists infinite numbers of you that go around killing cats for fun.Because the universe is infinite, there might be some other planet that happens to have Troglodons. Also, there's an infinite amount of universes in the multiverse, each one different from each other. Troglodons might be found in one of those universes.
Where the laws of physics could vary between universes. Then just about anything is possible.and that's even before you add in the multiverse theories.
Where there are an infinite amount of universes.
Agreed. @PhoenixTheCat was doing a little bit of stretching as a result of what I believe to be desperation.Even if there is a troglodon somewhere in the universe, we're still debating about things on Earth.
You'll have to ask @Lord Grok Of XillaquaAnd anyway, i barely see how a Komodo dragon is fitting in a thread about dogs vs cats...![]()
You never stated the limits. Therefore I started musing about life in other universes. You should consider the consequences of your actions more.Agreed. @PhoenixTheCat was doing a little bit of stretching as a result of what I believe to be desperation.
I think it fair to assume that "dogs vs. cats" as the topic title should be sufficient in terms of establishing the topic's limits. I don't think adding "earth bound..." is required.You never stated the limits. Therefore I started musing about life in other universes. You should consider the consequences of your actions more.
