KoW Salamander Colour Schemes
Discussion in 'Salamanders Discussion' started by BAE, May 16, 2016.
  1. BAE
    BAE Well-Known Member
    Thank you! However proud I am of the paint job on the Ankylodon, I'm not going to lose battles just to show him off :p If he had a 50x50 base I might use him as something else, but I'm not exposing additional flank for no benefit. He'll sit on my shelf until they hopefully tweak him into usefulness in KoW 3rd Ed!
  2. Itepixcauh
    Yeah, my mistake :p I was thinking of the Tyrants...
    Yeah I know he needs a point reduction to be really usefull, I'm just trying to justify myself on not taking him out :rolleyes:
    BAE likes this.
  3. BAE
    Haha Whatever floats your boat! The Ankylodon's defenders only ever suggest that he is 10-20 points overcosted, but I would only really consider taking him if he was about 50 points less. Although the stats might look amazing, in terms of actual battle-usefulness I feel he sits only just above a Greater Fire Elemental on his own. As they only really work in pairs (so that they can defend each other's flanks), this would mean spending 400 points on two, and that to me feels about right.
    Itepixcauh likes this.
  4. Jack Trowell
    Jack Trowell Active Member
    Well, in that situation I would use tha ankylodon combined with another unit to kill the elementals faster, i keep seeing its small frontage mentionned as a negative but in most situations it's great to be so small, as it allow you to fit several chargers against the same target.
    Now imagine something like an ankylodon supported by two greater fire elementals ont the side, all 3 should be able to combo charge on most units at the same time, and if later you starts to feel the "heat" from your opponent counter attacks the ankylodon might contnue to hold the ennemies while the elementals would redirect toward other targets if you feel they took too much damage.
    It's just an exemple of course, I am perfectly aware that it's harder to use in an optimal manner the ankylodon, but I see potential with it. In any case, due to his point cost and versability using it to the best will certainly require thinking about how he can support or be supported by the rest of the army so that you don't waste this potential. If you use him only has a hammer, sure the greater fire elemental will be better.
    Crowsfoot and Itepixcauh like this.
  5. The_Howling_Banshee
    The_Howling_Banshee New Member
    just head in and smash everything!!
    :turtle:
    Banshee
  6. BAE
    Thanks to @Crowsfoot for explaining how to make a molten lava base! (I've done the rocks slightly incorrectly, but I won't make the same mistake when I do that style of base again.) And a Greater Fire Elemental and some Fire Elementals. These were done super quickly to be able to play them at the Clash of Kings, hence they're a bit messy, but they'll do to put on a table. I can always buy some more after the competition and paint them better.
    Warden, n810, Bowser and 4 others like this.
  7. Itepixcauh
    That GFE looks amazing man! Absolutely brilliant fire, WOW
  8. BAE
    Thank you! Although I may have cheated a little bit by using GW Dry paints... Basecoated White Scar then Flash Gitz Yellow heavily diluted with Lahmian Medium. After that, dry brush Kindleflame and Astorath Red, then Fuegan Orange shade applied as though dry brushing. Finally, White Scar w/ Lahmian Medium to pick out the crevices, and Abbadon Black on the tips. Took all of 2 hours to finish after I'd applied the 4 or 5 layers of White Scar it needed to get a solid white base.
    I could have done him better with a bit more care, but with it being a £7 model it's not going to break the bank if I ever feel like doing another!
    Bowser and Itepixcauh like this.
  9. BAE
    @Crowsfoot - How do you do 'normal' bases please? I've got sand but the PVA glue doesn't seem to stick it down - I even put a watered down pva over the top like videos on Youtube suggest, but that also doesn't seem to do anything...
  10. Itepixcauh
    I do just that; pva, then sand, and while it's still fresh watered down pva very carefully and let dry for a long time. Never had any problem with that.
  11. Crowsfoot
    What sand have you got? Is it dry? Is the pva glue mixed well it sometimes separates.
    I've never had a problem with it
  12. BAE
    Key words in that post: "a long time". Rookie mistake on my part... All sorted! :oops: Glued into troops with self-adhesive magnetic rubber on the underside of each troop. I had mild steel sheet custom cut to the sizes of regiments and hordes so now I can magnetise multiple troops as required for any list.
  13. Crowsfoot
    They look cool, the basing is very similar to mine will post a pic tonight.
    Warden, Bowser, BAE and 1 other person like this.
  14. Bowser
    Your greater fire elemental looks incredible! Fantastic job! The base look spectacular! Just so much awesome here!
  15. Itepixcauh
    The true genius here is, how did you managed to rank them up! They are a nightmare to rank properly
    Warden, Crowsfoot and Bowser like this.
  16. BAE
    They are as easy as breathing compared to ranking up Mantic's Salamander models! After the hell I went through with the Salamanders, the Ghekkotah were an absolute joy to work out.
  17. Crowsfoot
    I think they build as a straight tail, left tail and right tail so just inter mix them, I found the guard a NIGHTMARE
  18. Crowsfoot
    Pics as promised,
    Warden, Bowser, n810 and 1 other person like this.
  19. BAE
    They're amazing!!
    How did you get the dots on the eyes?
  20. Crowsfoot
    n810 and BAE like this.
