AoS Saurus unpopularity
Discussion in 'Seraphon Discussion' started by 4idvet, Jun 28, 2020.
  1. Dread Saurian
    I think point cost shouldn't matter too much if they got advance and charge added to em that way they can justify the cost eh?
    Lizerd and Putzfrau like this.
  2. Putzfrau
    Totally, but gw usually doesn't adjust rules after a book comes out unless its something super messed up. So realistically theyd get a points dip, if anything.
    Lizerd and Dread Saurian like this.
  3. Dread Saurian
    Ugh the laziness I can smell it from GW no backbone from them q.q
    Lizerd likes this.
  4. Erta Wanderer
    yep i run 90 and i do fine. saurus are solid even in competitive i can go 4 and 1
  5. Killer Angel
    How do you manage to move all those models in tournaments, when time is a factor?
    Putzfrau, Lizerd and Erta Wanderer like this.
  6. Erta Wanderer
    5 and 10 man movement trays same as when i used skinks but now only 90 models instead of 200+. trays are removed when charging or dealing with tight terrain.
    Lizerd likes this.
  7. Killer Angel
    makes sense.
    Yeah, when playing saurus warriors a single horde is not enough, as it can be easily contained, but with 2 of them…
  8. Erta Wanderer
    2 of them backed up with 10 man skink screens and kroxigore. mmmm happy lizard noises
    Lizerd likes this.
  9. Grotpunter
    Grotpunter Well-Known Member
    Cant you just measure the front and push the remaining up behind them? Never had an issue with not measuring distance on every single model
    Canas, Lizerd and Dread Saurian like this.
  10. Dread Saurian
    Yes you can. You can do that whenever you want. Only thing it affects is difficult terrain
    Canas and Lizerd like this.
  11. Lizerd
    Lizerd Well-Known Member
    you can push them up, but lack of caution means they could be damaged (the models). Personally i would move a few as lynchpins and move everyone else up to them
  12. Putzfrau
    When i was playing my old Fangs of Sotek list from the first book it's just a lot of practice. I knew what i wanted to do and was used to moving that many models.
    The only time i had problems is when my whole army would get stuck in with another army with a ton of models (like DoK) from an early turn. The combat rounds just take so long lol.
    also, 40k may have helped me. Age of Sigmar takes less time than 40k in my experience and I was used to cramming 40k games into 2 and a half hours.
    Killer Angel and Erta Wanderer like this.
  13. Grotpunter
    I always seal my models once they are painted (painting is easily the least enjoyable aspect of the game for me, so there is no risk of wanting to re-paint something ever) but I was thinking of gently pushing models forward. You could also grab a couple at a time quickly and move them up behind the others once the front line is measured correctly. I actually dont really like movement trays and feel they make things too awkward. The only time I ever use a movement tray is those skirmish ones for Skinks where there is exactly 1" between each Skink so they string out and screen as effective as possible. I dont want to sit and measure 1" between each Skink after each movement.
    Lizerd likes this.
  14. ILKAIN
    ILKAIN Well-Known Member
    I think not changing their wardrum ability would have been enough to make them better, run and charge would seem a little too strong IMO, as most things with that ability on their warscroll are very specialized for it, and others that grant it either take up a CP or a spell cast.
    Lizerd likes this.
  15. Putzfrau
    Ehhhhh, I think i might prefer reroll charges over an automatic 5'' run.
    I think they should have gotten run and charge with a prayer, cp, or spell cast like you said. The old blood on foot should have done it, or the skink priest prayer should work on saurus, or it should be part of the slann lore with its 2 good spells.
    Any of those options would instantly make saurus viable and not be overpowered.
  16. ILKAIN
    yeah of course.. I just don't think they should have it for free on their warscroll
  17. 4idvet
    4idvet Member
    So now that every model is finally assembled, next weekend I’m going to run the saurus battalions against my girlfriends bonereapers and then her lumineth. I only have one salamander so It’s gonna be a battle of infantry with bonereapers. I believe fighting both those armies every week will surely be a good way to get great with them. I will for sure keep y’all posted on the games and can demo any list ideas or things you’d like for me to try against them.
    Lizerd likes this.
  18. Dread Saurian
    Its not for free its just adding something to justify the cost ;)
    Lizerd likes this.
  19. Dread Saurian
    Careful mate lumimeth and bonereapers are some choice armies.
    Lizerd likes this.
  20. 4idvet
    4idvet Member
    Alas it’s what she’s got lol. She has the models for any battalion of reapers so it’s either gonna be mortek and catapults or cavalry doom lol.
    Lizerd, Putzfrau and Erta Wanderer like this.
