AoS Should I go 10/30 or 20/20 on javelin/boltspitter Skinks?
Discussion in 'Seraphon Tactics' started by DarkStar5758, Jan 9, 2019.
  1. Make 10 of both
    2 vote(s)
    16.7%
  2. Make 20 with boltspitters
    10 vote(s)
    83.3%
  1. DarkStar5758
    DarkStar5758 New Member
    I currently have 10 of both Skinks with javelins and boltspitters and have another box of them on the way but I'm not sure whether it would be better to add 10 to each unit to give them both +1 to hit or go all in on the Boltspitters for +2 to hit for them.
    If it helps, I'm currently trying to build towards a Shadowstrike Starhost and my current inventory is:
    1x Lord Kroak
    1x Skink Starpriest
    1x Skink Priest
    10x Skinks w/ javelins
    10x Skinks w/ boltspitters
    5x Chameleon Skinks
    3x Skink Handlers
    1x Saurus Scar-Vet on a Carnosaur w/ spear
    1x Saurus Scar-Vet on a Cold One
    1x Saurus Sunblood
    1x Astrolith Bearer
    10x Saurus Warriors w/ spears
    5x Saurus Knights w/ lances
    1x Bastiladon w/ solar engine
    1x Razordon
  2. GuaDan
    GuaDan Well-Known Member
    I would go full in on the spitters.
    Currently the only way to make skinks significant damage-wise is the 40 man boltspitter blob, but their main use remains being quintessential supreme chaff.
  3. Canas
    Spitters win on account of their added range. Not that either is going to do any significant damage anyway, but at least they can try from a bit further away.
    I mostly just build the javalins on the side. Seeing as each box comes with 24 of the things anyways I build 20 spitters and 4 javalins. If ever javalins get a buff I'l be prepared :p
  4. Aginor
    I would also go for only Boltspitters.
  5. serafellow
    serafellow New Member
    I’d go for bolt spitters. I have all my skinks with boltspitters and they are pretty good at poking at things from range, and occasionally doing a wound or 2. They can actually do well(ish) against 6+ save things like Beastmen chaff.
  6. Vexcor
    Vexcor Well-Known Member
    is it possible to give skinks boltspitters and shields?
    Because in the Warscroll there is a melee combat table for boltspitters and for clubs, so can you choose between clubs and shields?
  7. serafellow
    Yep that is perfectly legal. And my preferred loadout!
  8. Torxhol Drakescale
    Torxhol Drakescale Active Member
    I always preferred javelins for the better wounds, because I tend to use them as roadblocks in bricks of 20, so 8 inch move with a 4/4 shooting attack is a pretty threatening roadblock.
  9. Vexcor
    i like javelins a lot, the only bad side is that LoTaS set up 9 inch away :(
    just 1 inch more and it would be awesome!
    ILKAIN likes this.
  10. ILKAIN
    ILKAIN Well-Known Member
    Maybe we can hope for that in our new book... whenever we get it :(
  11. Aginor
    IMO the better range of the boltspitters more than makes up for the lower damage.
    GuaDan likes this.
  12. ILKAIN
    SO I did some testing based on reading some stuff on here, played 4 games this past weekend, varying points, all games summoning/shadowstrike focused builds. played Sylvaneth, SCE, Death (Vampires) and Slaves with an Archaeon. for the layout of my skinks I went with Boltspitters and shields for the 40 man block I used in the battalion, to give them range and durability, expecting to use them as a more than one turn screen or objective holders. For the skinks I summoned in, I gave them clubs and spears, and used them basically as speed bumps. those speed bumps took the undercarriage out of a lot more than I expected. was able to keep archaeon off two objectives two waves of ten skinks armed this way... which kept him in range of the Bastilodon shooting him (from 20 inches away cuz that three headed beast is terrifying lol) didn't kill the archaeon because he ended up realizing I was doing serious damage, (a good 5/6 done by the speed bumps!) and pulled him out of range in round 5.
    TLDR spears and clubs are a good idea for summoning chaff if you can control that they are going to do the charge not be charged. still prefer boltspitters and shields for the large "list" units to protect against losses( battleshock too) and hold what they need to hold/Losat and shoot that round.
  13. Killer Angel
    I tend to use boltsplitters.
    When you shoot with javelins you are basically in melee… and if your skinks block is enough threatening, then the enemy is not going to let you use wary fighter.
  14. Torxhol Drakescale
    I tend to use javelins to support my warriors in the sunclaw, generally 20 man bricks. an extra 20 attacks at a 4/4 isn't bad.
  15. Colossal Marlin
    Colossal Marlin Member
    I tend to mix, but lean heavily towards spitters and shields. I like to summon javelins if I'm desperate and have 6CC points going spare, but mostly I'd stick to boltspitters for the extra range and annoyance they can cause.
  16. Val Muna
    Val Muna Active Member
    OK - very VERY Stupid question here: When you are building your army, you have to consider summoning when it comes to fielding models, i mean of course you do. So if you have a list of say 60 skinks of the board, and you're planning on maybe summoning skinks, you need to be bringing something more like 80+ skinks, and some salamanders, and some of whatever it is you are planning on summoning, even potentially. So really to build a 1000 pt summoning army, you need to buy and bring ~1500 pts in army +options. And if you want to summon something, but don't have the extra models off-board - you can't(?). I know that seems obvious, but i never really hear it talked about, when buying and building lists.
  17. Crowsfoot
    Yes your right but when your skinks get killed and removed you can use them as a unit of 10, same with Salamanders and Razordons, well everything really.
    But yes you really want a reserve of 20 skinks and a Salamander, Razordon etc etc
    Val Muna likes this.
  18. Canas
    I think it's not talked about much cuz nearly everyone who plays this seriously enough to be interested in talking about it probably has enough models to spare for some summoning anyway. I mean let's face it, most of us probably have enough to field our main army three times over if needed (with the possible exception of some extra special stuff.. like I doubt many people have multiple Kroaks or multiple archeons)…
    Crowsfoot and Val Muna like this.
  19. Crowsfoot
    Very true but someone new to the hobby might not grasp that in the beginning.
  20. Canas
    o the sweet innocence, back when you thought you didn't need that 50th box of models :p
