VampTeddy
Active Member
Sleboda said:Phatmotha-phucka said:Sleboda said:=> No, it's a miniature wargaming thing. It's a gentlemanly gamer thing. It's the right thing.
You are not entitled to lay this out as a fact or lay claim to "the right thing".
Nothing can grind my gears as much as people who are "certain" that they figured out the "one right way" to do things. For a guy with "True scholars have more than just one book to study." as your signature YOU MUST be able to appreciate what I am saying here.
=> I understand your points, but largely disagree with them. If I am given a choice to take one of two actions, and one is self-serving at the expense of fairness to my opponent, you can bet I think the _other_ choice is indeed "the right thing."
It's the old Golden Rule thing again.
The Western version is far too self-centered compared to the Eastern.
Western: Do unto others as you would have them do unto you.
Eastern: Do nothing to other that you would not have done to you.
In other words:
Western: Hey, if it's something I like, then I'll do it since I wouldn't mind someone else doing it.
Eastern: Hey, I really wound't want someone to do that to me, so I won't do it to someone else.
Hobby:
Western: I don't mind when someone plays with misleading models, so that's how I will play too.
Eastern: I don't like it when others use the wrong models, so I won't do that to someone else.
Lizardmatt said:Magic items are kept secret, and are not WYSIWYG for the most part. Magic gear that is defined as mundane items (such as glittering scales "light armor", armor of Destiny "Heavy Armor", Charmed shield "Shield". Some much items are defined as mundane weapons, such as a spear or lance.
WYSIWYG, you'd want to have armor/shield/lance/spear as appropriate, but outside of that, it's not required to be modeled.
=> Fer sher. That's the standard minimum, and nobody should fuss as long as that's met. I know I take it upon myself to go even further down the path of being considerate to my opponents, but not everyone does and that's ok.
Forums are great because we can discuss many things, including ideals. Let's take the Cloak:
Ideal - The model has a feathered cloak and so you pay for the Cloak of Feathers or use another model.
Middle - You use that model but don't take the Cloak.
Crappy/Bad Sport/Questionable Intent - You have two skink priests. One model has the feathered cloak and the other does not. The one without the feathered cloak gets the Cloak of Feathers.
You have to question a player that would do the last. Why? Why attempt to deceive? Sure, the rules don't prevent you from doing this, I know, but it says a lot about the character of the player if he does it anyway. I mean, how hard would it be to simply swap the models? You still don't have to confirm who has what, but at least you are not deliberately trying to deceive your opponent.
I would always go to the length, at the start of battle, to tell my opponent what is what if i can't WYSIWYG (the GW example is a golden one here).
This means that i'll tell my opponent when i deploy my hero "this guy "obviously" (ironically offc) has a GW", since i am not currently able to provide a model with a great weapon, i tell my opponent that what he's seeing is actually something else - a courtesy i haven't been met with by my opponents, but i do it nonetheless "what you can see on this model is : etc. etc. etc." with the model range supplied and my current painting progress i have to, to be able to field what i want to field - as an example a skink chief in LA is currently impossible to field - none of them bear light armor, one of the bears a helmet. But my opponent SHOULD be able to see the LA, and so i tell him i have it.
I know it isn't as hard as your route, nor actually as hard as your middle route, but i don't see why it shouldn't be accepted as long as i clarify with my opponent once i deploy my characters!
