AoS Spells and mounts
Discussion in 'Rules Help' started by Tizianolol, Sep 4, 2017.
  1. Tizianolol
    Tizianolol Active Member
    Guys i have 2 questions
    - spells like loremaster normaly works on mounts right?
    - on a unit of cavs like demigryph knights can i buff mount too?
  2. Stormscales
    Stormscales Member
    Pretty sure the mount is not considered separate from the rider in Age of Sigmar, unlike Warhammer Fantasy. Whatever affects the rider affects the mount, and vice versa, except otherwise stated.
  3. m0gstar
    m0gstar Well-Known Member
    Usually yes, If spells have a restriction, it is usually mentioned within the description of the item or spell. Otherwise, the spell or item should affect the entire warscroll which includes both rider and mount
  4. Tizianolol
    Ok thx because i have seen in YouTube a mc1gamer about demigryph and he said you can t buff mount anymore. I know about hero with mount ( page 117 ghb2) but I thought normal mounted model you could buff mount!;)
  5. Ecozh
    Ecozh Active Member
    Command traits/relic only affect the rider but that is explicit stated in GHB (and the faq)
    Page 117 – Allegiance Abilities, Mounts
    Change the second sentence to:
    β€˜In all such cases, any command traits or magical artefacts can only be used to affect attacks made by the hero, and have no effect on attacks made by the their mount unless speci cally stated otherwise.’
    Says nothing about spells, command abilities etc.
    Killer Angel and Tizianolol like this.
