7th Ed. Standard 2000k
Discussion in 'Lizardmen & Saurian Ancients Army Lists' started by Ade, Jun 23, 2008.
  1. Ade
    Ade New Member
    Any comments on the list below cheers
    Saurus Warriors (16#, 222 Pts)
    15 Saurus Warriors @ 222 Pts
    Musician Mus; Standard Bearer Std; Hand Weapon; Shield; Scaly Skin
    1 Spawning Champion @ [] Pts
    Hand Weapon; Shield
    Saurus Scar-Veteran (16#, 320 Pts)
    1 Saurus Scar-Veteran @ 122 Pts
    Hand Weapon; Light Armour; Scaly Skin
    1 Burning Blade of Chotec @ [] Pts
    1 Enchanted Shield @ [] Pts
    15 Saurus Warriors @ 198 Pts
    Skink Skirmishers (10#, 60 Pts)
    10 Skink Skirmishers @ 60 Pts
    Hand Weapon; Blowpipe; Aquatic; Skirmishers
    Hand Weapon; Javelin & Shield; Aquatic; Skirmishers
    Krogixor (3#, 174 Pts)
    3 Kroxigor @ 174 Pts
    Great Weapon; Aquatic; Causes Fear; Scaly Skin
    Salamander (12#, 195 Pts)
    3 Salamander @ 195 Pts
    Causes Fear; Scaly Skin; Skirmishers
    9 Skink Handlers @ [] Pts
    Hand Weapon; Aquatic; Skirmishers
    Slaan Mage-Priest (17#, 797 Pts)
    1 Slann Mage-Priest (Battle Standard Bearer) @ 490 Pts
    4th Generation; General; Battle Standard Bearer; Large Target
    1 Plaque of Dominion @ [] Pts
    1 Plaque of Tepok @ [] Pts
    1 Diadem of Power @ [] Pts
    15 Temple Guard @ 307 Pts
    Musician Mus; Standard Bearer Std; Hand Weapon; Halberd; Scaly Skin
    1 Revered Guardian @ [] Pts
    Skink Priest (1#, 150 Pts)
    1 Skink Priest @ 150 Pts
    Level 2 Upgrade; Hand Weapon; Aquatic
    2 Dispel Scroll @ [] Pts
    Total Roster Cost: 1978
  2. SohCahToa
    SohCahToa New Member
    Looks like a good starting point, you may find that the 16 Saurus Regiment is a rather arbitrary size as you continue (dont forget you only get a rank if it is 5 wide).
    Be careful about posting point values for individual upgrades, as it is against the rules for this forum and indeed all GW-related forums. Keep in mind that if you copy and paste from army builder you will have to edit out these point values.
  3. Ade
    Ade New Member
    Thanks for the advice with regards cutting and pasting from army builder (That's what you get for rushing it in the lunch hour). I hadn't realised you only rank bonus unless they where 5 wide (I'll go back and re-read the rule book). I will have to a play around and see if I can get 2 20 strong units in there maybe drop 1 unit of skinks.
    Cheers
    Ade
  4. SohCahToa
    I would suggest against dropping the unit of skinks from the list. Keep in mind that Lizardmen benefit the most from a flexible list. Your list already suffers from a certain rigidness, with no viable war-machine or mage hunting unit, and little in the way of manuverability. If anything, I would suggest considering at the very least a JSOD, or better a unit of terries, but certainly do not drop the skinks.
    P.S. Dont forget that you are 22 points under aswell
  5. Ade
    Ade New Member
    Hi I have done a bit of rework taking onboard your suggestions here is the revised list I have knocked out one unit of Saurus, increased the other to 20 and put in a unit of Terradons let me know what you think
    1 Enchanted Shield
    19 Saurus Warriors @ 246 Pts
    9 Skink Handlers
    1 Plaque of Tepok
    1 Diadem of Powers
    16 Temple Guard @ 324 Pts
    1 Revered Guardian
    2 Dispel Scrol
    5 Terradon & Rider @ 175 Pts
    Hand Weapon; Javelin; Flyer
    Total Roster Cost: 1996
  6. SohCahToa
    Looks good. Its a little small for my taste, but if you can swing it go for it. The terradons will definately help you with the war machine hunting, especially important as you have not given your slann a plaque of protection.
  7. Doom Lizard
    Doom Lizard New Member
    Just a quick suggestion. You should post your army list order going from Lords, Heros, Core, Special, Rare. Just so you dont confuse us simpler folk :)
  8. SohCahToa
    Yea, generally speaking Army Builder never really translates well into forum discussion.
  9. Doom Lizard
    Man, what happened to pencil and paper. maybe a calculator if your feeling really lazy. Writing army lists is part of the fun. Oh and as a side note, i just noticed our character cap on posting in 60,000 characters!!! That's awesomely a lot :) sorry.
  10. SohCahToa
    Off topic: Hey, dont knock army builder until you try it. Although, as evident, its hard to break the addiction sometimes and just type/write out the list ;) .
    On topic: You may want to consider the Sword of might rather than the BBoC, as it will serve you better in the long run IMO. While both will affect the probability of causing a wound twice, the Sword of Might will still benefit you even if your strength already negates their armor save (think T4 light armored troops like Orks, Beastmen, and Nurgle Daemons).
  11. El_Collyero
    El_Collyero New Member
