Blog Starting my seraphon painting
Discussion in 'Personal Paint Logs' started by John1974, May 15, 2018.
  1. John1974
    John1974 Active Member
    Cheers Warden appreciate the kind words. Trying to get back into it is always fun
  2. John1974
    So i think im close to finishing my bastiladon.. This is the 1st minature that ive ever done a basing for and it was hard to decide on what too much decoration and what wasnt enough lol...so i thought id give him a swampy theme.. Anyway ill post all the pics and please let me know if its too much or not enough cheers...
    ive tried out some stuff i found at the local hobby store called AK water gel swamp green
    glued down 2 large rocks for the front feet to plant on and the swamp green gel.. starts off a creamy white then goes to a darker green as it slowly dries
    ive snapped a small twig from outside to make it look like the bastiladon has smashed through it and broken it down
    a standing tree with rocks and moss
    added some stones into the back and a larger one to the front
  3. John1974
    final product for now.. the white gel look will darken up and go green with a little time
    .. just feel like it needs a little something at the front and right side.. maybe some sand or moss what do you think??
  4. Ritual
    Ritual Well-Known Member
    That water gel stuff looks interesting! Next time I would definitely build the base up and apply that last. I wouldn't go OTT on adding stuff to the front, you don't want to distract people from the model itself.
    If I could offer any other advice it would be to paint the other additions ot the base such as the foliage and branches... At the moment they look like stuff stuck on the base, not part of the base itself.
    Crowsfoot, Warden and John1974 like this.
  5. John1974
    cheers Ritual... yeah iv tried to place the green gel onto the rocks to make them look like its lapping onto the rocks.. definately looks like ive missed a few cheers.. when the green gel dries ill try and touch it up abit around the bottom where the sand at the back meets the swamp and ill paint the rocks as well..And definately paint the branches and trees to make it fit in more.. thanks for that appriciate the tip
    Crowsfoot, Warden and Ritual like this.
  6. Ritual
    Also love the old style paint pots, brings back memories!
    Crowsfoot and John1974 like this.
  7. Crowsfoot
  8. John1974
    So decided to add some dry brushing to the swamp on the bastiladon
    Warden, Aginor, tom ndege and 2 others like this.
  9. John1974
    Also started on my skink bases
    This the base after painting it
    And this is after placing some resin on it to TRY and achieve a wet, flowing effect
  10. John1974
    And a couple more done
  11. Crowsfoot
    Looking good ;)
    John1974 likes this.
  12. Aginor
    Yep. :)
  13. Joshua Horchler
    Good work mate! Really nice bases. Do you use actual rocks for your rocks? It's a silly question but I was curious. I have found that bark or cork makes for better rocks than actually rocks. It can be really cheap or free (walk outside or go to a store and ask for a sample). Maybe worth trying if you're not satisfied with your current aesthetic.
    I see a very green Stegadon hiding in the background :) Looking forward to seeing that one!!
  14. John1974
    Hey Joshua with the skinks ive used a mix of real stones and hot glue mounds.. I've noticed alot of peopke using cork, so i might give it a go cheers
    Joshua Horchler likes this.
  15. Joshua Horchler
    All personal preference! Cork and bark do make better pieces for dry brushing. No round edges! :)
  16. John1974
    And that's the unit finished
  17. John1974
    Also finished my slann.. though im not really happy with the paint job. I really hate painting on finecast.. but it is what it is i guess
  18. John1974
    And onto my 2nd unit of skinks. Just gotta do some touch ups on the paint . Teeth and claws and bases.
    Noobdar, Warden, tom ndege and 2 others like this.
  19. Aginor
    Nice work on those. I like the little rainbow feathers.
  20. John1974
    So been working on my slann base coming along. Pretty happy with the result so far
    Im gonna try using VMS smart mud on the base
    So this is the base as i go along
    so still not quite finished got 1 snake and the 2 skinks to finish painting then glue it down
